Old 12-24-2014, 06:30 PM   #1
chuckclanton
Drives: 2021 Camaro 2LT
1LE rear tire right size?
Seems to me the rear tire should be at least a 295/35/20 as the wheel is 11in. They must have used the 11in wheel because it was already on the ZL1? TireRack shows the 285/35/20 its okay on an 11 but it doesnl look right to me.
chuckclanton is offline   Reply With Quote
Old 12-24-2014, 06:43 PM   #2
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Nah, it's all good. I had a 305 on it and to be honest I like the 285 better.
Stock Boy is offline   Reply With Quote
Old 12-24-2014, 06:57 PM   #3
Bens1le
Bens1LE
Bens1le's Avatar
Drives: 2014 ss 1LE
Tires
I got the michelin pilot super sports
285 front and 295 rear from clay at tire rack
And couldn't be happier
Bens1le is offline   Reply With Quote
Old 12-24-2014, 07:06 PM   #4
chuckclanton
That makes sense. I will do the same when my car comes in.
Old 12-24-2014, 07:07 PM   #5
Cleancoupe
Drives: 18 ZL1 1LE
They did a 285 on the rear for a square setup. This reduces understeer. The 285 is stretched out a bit on a 11" wheel, but it works. I seen a thread a while back that said these split 5 spoke wheels were actually designed for the 1LE which is why they don't have ZL1 stamped on them like how the other solid 5 spoke wheels that come on the ZL1 do. I'm not sure how true that is or not.
Cleancoupe is offline   Reply With Quote
Old 12-24-2014, 09:01 PM   #6
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
The tire size is supposed to be that way. It makes the car neutral when driving hard through turns.
Bhobbs is offline   Reply With Quote
