Old 12-26-2014, 06:49 PM   #1
whamslam3
Camaro King [^*^*^]
whamslam3's Avatar
Drives: Apollo 11 Camaro IOM
Question Razzi Front Install?
so eventually i want to get the razzi front splitter. i am worried about the install because i had a splitter on my car already and i hit it on something and it kind of tore the bottom of my front valance a little bit where the screws were on one side. so i am assuming this one will screw in that same area where i cant put a screw anymore so what can i do?
whamslam3 is offline   Reply With Quote
Old 12-27-2014, 10:33 AM   #2
zandron263
zandron263's Avatar
Drives: 2011 2LT RS IOM Convertible
When I attached mine there were 2 plastic L brackets that mounted inside the front wheel wells. The splitter screwed to those and the only other fastening was done with glue or double sided tape. There were no mechanical fasteners on the bottom. This was on the V6 bumper I don't know if it is different on the V8 bumper.
zandron263 is offline   Reply With Quote
Old 12-27-2014, 02:23 PM   #3
whamslam3
Camaro King [^*^*^]
whamslam3's Avatar
o ok thanks sounds like it will be ok then
Old 01-18-2015, 05:32 PM   #4
chris1973
chris1973's Avatar
Drives: 2010 Camaro 2SS/RS Black on Black
I just installed my yesterday. He is correct. Also search the forums one DIY recommended (and did it) adding a screws or rivets underneath. I did the install with screws. Once everything was perfect I replaced the screws with pop rivets. You can get a rivet gun at any Home Depot or HW store for <$20.00.
Good luck.
2010 Camaro 2SS/RS
Black on Black
Performance Mods: CAI, ADM Scoop, Rotofab Washer Kit, Cat Back Borla ATK, SLP Underdrive Pulley, SCT Tune, DynaTech Long Tube Headers and High Flow Cats.
Appearance Mods: Razzi Bodykit with LEDs, 3D Carbon Side Vents, Tint, Painted Rims and Calipers,
See/hear my Camaro at
http://youtu.be/wn0Ck-cw6WQ
chris1973 is offline   Reply With Quote
