Old 12-26-2014, 08:03 PM   #1
camarocruzer
camarocruzer's Avatar
Drives: White 2014 2SS/RS Coupe
Car died
So about a month and a half ago, I went in and started my car and it went dead. D. E. A. D.
I called roadside assistance and they came and jumped it and it has been fine. Brought it to the dealer (it's 6 months old) and they said they cannot find the cause or any issues related to the battery or electrical system. Fine. Brought it home.
Fast forward to today. I haven't driven it in about 5 days. Went in today to turn it on and bzzzzt. Nothing. Windows went up and down, doors opened and locked, windshield wipers flicked and I heard clicking.
The thing the dealer told me last time was if it happens again, tow it in and do not jump it. So I did. Figure they will get to it Monday morning. Before I handed it off to the driver, and it didn't do this last time -- on this DIC it said "battery saver active".
Personally, I think it is the battery......
2014 Summit White 2SS/RS, L99
CAI by Cold Air Inductions, Inc with Strong MAF Sensor / Borla ATAK Cat-Back Exhaust / SOLO Performance High Flow Catalytic Converters / SOLO J-Pipes / Vitesse Throttle Controller / Apex Catch Can / Vmax Ported Throttle Body / Range v8 AFM Disable Module by Range Technology / SLP Fade to Black Side Gill Decals / APEX Washer Replacement System and CAI Scoop / BMR Front and Rear Sway Bars / BMR Rear Trailing Arms / BMR Front End Links
camarocruzer is offline   Reply With Quote
Old 12-26-2014, 09:09 PM   #2
CALLAWAY11
CALLAWAY11's Avatar
Drives: 2011 2SS/RS Callaway
Anything aftermarket? I have the technostalgia tail lights and that's happening to my battery as we speak.
CALLAWAY11 is offline   Reply With Quote
Old 12-26-2014, 10:40 PM   #3
jgray1978
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
Originally Posted by camarocruzer View Post
...I went in and started my car and it went dead. D. E. A. D....
So it started and then died?
jgray1978 is offline   Reply With Quote
Old 12-29-2014, 03:25 PM   #4
camarocruzer
Nope. It was last started about 4 days prior. Then Friday I got in, tried to start it and you could hear something make a power down sound (like it were a droid...) then clicking all over the place.
And, I just called the dealer and told them that like last time, a few days prior to each event, I had a info on my display telling me to reset my windows by rolling them down then up.
Figured that may point them in the right direction.
And, since they said last time it wasn't the battery and they couldn't detect a short, it was something they couldn't find (hence "don't jump it next time, bring it in dead").
So now I'm thinking (and hopefully they are also) computer???
On another note, is there a battery disconnect so if you're not in it for a week you just flip the switch and the battery is saved from something like this??
Old 12-29-2014, 04:14 PM   #5
avido
Drives: camaro ss\rs
check what absorb energy from the battery.
avido is offline   Reply With Quote
Old 12-30-2014, 06:00 AM   #6
camarocruzer
How do I check if this little module draws any current? Can I hook it up to a voltmeter and check?
This is the item. http://www.rangetechnology.com/pages/v8
Old 12-30-2014, 10:35 AM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
The original version technostalgia lights sold up until mid '14 pulled a constant 90ma so depending on the state of your battery and other acc amps draws after 5 days of not driving the battery could die ( the lights will starts flashing first to let you know the battery is low. This battery draw and flashing lights happens even if you do NOT have Showmode wired. If you're not going to drive it for 5 days or more then hook up your battery to a battery tender. Search the forum and you'll find plenty of posts about this .
camguynj is offline   Reply With Quote
