Old 12-27-2014, 10:55 AM   #1
mojatto
mojatto's Avatar
Drives: 2019 Camaro 2.0T (European version)
Disk rotor question: differences
from Camaro5 Wiki:
2010 SS OEM Brakes:
ABS
ventilated front and rear rotors
four piston fixed Brembo aluminum front and rear calipers
Rotor diameter (front) (in / mm): 14 / 355
Rotor diameter (rear) (in / mm): 14.4 / 365 / 315
Rotor thickness (front) (in / mm): 1.26 / 32
Rotor thickness (rear) (in / mm): 1.1 / 28
if a rotor is identified with the same parameters (diameter and thickness), why can not i mount other disk rotors (es. 355/32 1-piece or 2-piece bmw, porsche, ferrari) ?
are there other parameters that identified exactly a disk rotors ?
mojatto is offline   Reply With Quote
Old 12-27-2014, 12:09 PM   #2
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
The bolt pattern of the rotor hat, the offset the rotor hat had to the disc it self.
Caswell239 is offline   Reply With Quote
brembo; brake; rotor
