Old 12-28-2014, 07:38 AM   #1
DARKTHIRTY777
DARKTHIRTY777's Avatar
Drives: 2011 camaro ss
boost gauge wiring
Where are you guys installing the hot wire for your aftermarket boost gauges?
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
DARKTHIRTY777 is offline   Reply With Quote
Old 12-31-2014, 09:23 AM   #2
DARKTHIRTY777
Man nobody
Old 12-31-2014, 11:53 PM   #3
3400
3400's Avatar
Drives: 2013 2LT/RS
Originally Posted by DARKTHIRTY777 View Post
Man nobody
you looking for constant power or ignition power?
3400 is offline   Reply With Quote
Old 01-01-2015, 08:33 AM   #4
DARKTHIRTY777
Not constant power. Just when the headlights come on.
Old 01-01-2015, 09:43 AM   #5
jgray1978
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
Presuming that you are trying to wire the back light so that it illuminates when the headlights are on, you really want to hit the parking light circuit instead.
Purple and brown/white at the BCM - black plug, pins 6 and 5. Tap either one. They are both +.
jgray1978 is offline   Reply With Quote
Old 01-02-2015, 08:37 AM   #6
DARKTHIRTY777
Thanks jgray. Yes that's what I was looking to do, the back light
Old 01-02-2015, 09:27 AM   #7
DARKTHIRTY777
is the bcm located under the steering column
Old 01-02-2015, 11:22 AM   #8
jgray1978
It is in the dash above the peddles. Hang upside down looking up from the floor and you will see a series of colored square plugs. That's your BCM.
Old 01-02-2015, 08:30 PM   #9
DARKTHIRTY777
This must be it. Both wires or just one. Either the purple or the brown with white stripe. I circled the wires in red.
