Old 08-24-2009, 02:30 PM   #1
Mayhem
Mayhem's Avatar
Drives: 2010 2SS RS M6 Camaro (Black)
Updated GFX
Are people with the updated GFX generally problem free? Or are the new ones still causing a lot of grief ???
Really considering ditching mine before I pick up my car if they are gonna be that much of a hassle.... Although I prefer the look with them on....
I don't wanna be one of the "my dealer douched up my GFX and now I am waiting for a front lip" posts a few weeks from now.
PS - It would be helpful for those with problems/without problems if they could post the dates you got your ride with the GFX installed... to give an idea of how long until the problems surfaced. Thanks
Mayhem is offline   Reply With Quote
Old 08-24-2009, 02:47 PM   #2
BalogUK
THE architect.
Drives: 2SS/RS M6
there is no re-design. they clarified the install instructions on exactly how to attach the front splitter. problems surfaced almost immediately upon sustained highway speeds.
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 08-24-2009, 02:50 PM   #3
TeddyP25
TeddyP25's Avatar
Drives: 2SS
NO issues with mine, mine have the updated install. Been well over a 100mph for long distance without any issues....(knock on wood)
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 08-24-2009, 02:55 PM   #4
lbs13
Wilmes Winner!
lbs13's Avatar
Drives: RS/1SS/IBM
I really want the GFX but due to current funds I opted to due it later on. Is it best just to forget them or is it a small problem. I live on a gravel road so I don't want to trash the bottom of the car.
lbs13 is offline   Reply With Quote
Old 08-24-2009, 04:08 PM   #5
Mayhem
Mayhem's Avatar
Yeah I meant, since the new manufacturer & the new instructions...
More or less wondering for the most part if even with the "proper" instructions being brought to dealers attention more often because of the problems.... if the problems are still frequently occuring or if it was an adequate solution...
Old 08-24-2009, 04:09 PM   #6
Mayhem
Mayhem's Avatar
Good to hear , thanks for sharing
Curious, how long since attatched?
Old 08-24-2009, 04:27 PM   #7
CGM2SSRS
susp.ban4life!
CGM2SSRS's Avatar
Drives: Raptor
If installed correctly there should be no problems. Problem is dealers get paid 3 hours for the job and it takes like 8+. Which means the car wash guy is getting the job. No knock on the car wash guy intended. Pay the right person to do the job. The first time.
CGM2SSRS is offline   Reply With Quote
Old 08-24-2009, 04:41 PM   #8
Spaceballone
Drives: 1992 Custom RS, 2006 Civic
1 month`
1 month problem free, had her up pretty high and had no issues. right, there was no fix, it is just some of the dealerships were being lazy or not fully reading the instructions. GFX were getting installed without all 16 rivets/ screws. I looked under mine before i drove it off and you can see where they bolted that sucker on good!
Spaceballone is offline   Reply With Quote
Old 08-24-2009, 05:52 PM   #9
stretchfe
stretchfe's Avatar
Drives: 2SS/RS Black/Orange
I just had mine put on. According the dealer's body shop, they are slightly different than the original ones that came out with the way they tuck under the other body pieces. I opted not to have the front installed anyways.
stretchfe is offline   Reply With Quote
Old 08-24-2009, 06:52 PM   #10
2032Ceta
Drives: 2010 Camaro/2009 Nissan Rogue
I'll say it again, dealerships were taking shortcuts putting on the front splitter. The front bumper must come off to install rivets from the back side in the center of the splitter. Dealerships were not doing this and thinking the two sided tape would hold it. As we all know, it doesn't. They have updated the instructions, however even the copy I have from Feb 09 explain the procedure for the bumper removal. Long story short, it was an install issue.
2032Ceta is offline   Reply With Quote
Old 08-27-2009, 01:59 AM   #11
2010SSRSM6
2010SSRSM6's Avatar
Mine came with 2 right side hangers for the rear covers. Had to wait an extra day while the correct hanger was located at another dealership. Over 3K miles and speeds over 100+ m.p.h. with ZERO issues since install. Highly recommend them! I had to drive for 2 weeks with out them and you wouldn't believe the mess it made out of the rocker panels from rubber off the very soft PZero's and gunk off the roads. Worth every penny!
Old 09-04-2009, 10:43 AM   #12
capebretoner
capebretoner's Avatar
Drives: 2010 Camaro 2SS Black
my dealer still took the shortcut installing my second gfx front lip, now i have 2 destroyed gfx pieces, and ugly clips and urethane attached to my bumper..
capebretoner is offline   Reply With Quote
Old 09-04-2009, 11:54 AM   #13
dougcanuck
dougcanuck's Avatar
Drives: 2010 2SS Ralley Yellow, 6spd.
all depends on the Dealer putting them on...the guy's at Lakewood took extra time and care to make sure installation and fit were the best they could do...it's all about the people! thanks.
dougcanuck is offline   Reply With Quote
Old 09-04-2009, 12:46 PM   #14
ffrcobra_65
You nailed it. I totally agree. Folks, keep in mind, dealers are just learning to install the Camaro GFX. It is a learn on the job process as far as installation and final fit are concerned. I just picked mine up the other day and the dealer did as best they could but these GFX are essentially after-market add-on and fit is not 100% perfect. I am obssessive so a 100% to someone else may not be for me. I posted a couple of pics thread below.
http://www.camaro5.com/forums/showth...d=1#post885309
What Muffler desine/type would fit the GFX best? Li0nel1234 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-26-2009 09:23 AM
Has anyone painted GFX black to match stripes? Pics please! MajikMD Cosmetics and Lighting Modification Discussions 2 07-06-2009 07:49 PM
Question about GFX 91RS Cosmetics and Lighting Modification Discussions 3 06-15-2009 11:48 AM
