Old 12-29-2014, 06:09 PM   #1
iPaulll
iPaulll's Avatar
Drives: 2010 Camaro LT1
Fuse Question
Attempted to replace my license plate bulbs with new LED's (thinking that the old bulbs were burnt out). The new bulbs won't work either.
I'm thinking it's one of 2 things:
A. The fuse controlling the license bulbs
B. The license bulb assembly, wiring and all needs replaced.
Does anyone know what fuse is related to the license bulb?
iPaulll is offline   Reply With Quote
Old 12-29-2014, 06:58 PM   #2
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
1 Moment while I check Wiring Diagrams.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 12-29-2014, 06:59 PM   #3
iPaulll
iPaulll's Avatar
I've checked the diagrams and the only thing relative that I could find was 'trunk' fuse. I wouldn't think that would control the license bulbs though.
Old 12-29-2014, 07:04 PM   #4
Tricksta
Tricksta's Avatar
have you checked the ground wire?
Modifications
Old 12-29-2014, 07:08 PM   #5
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
have you checked the fuses in the trunk?
I think the trunk fuse is the fuse for that block.
GVA 45TH 2SS is offline   Reply With Quote
Old 12-29-2014, 07:09 PM   #6
iPaulll
iPaulll's Avatar
What's interesting though is the fact that my trunk light still works.
Old 12-29-2014, 07:15 PM   #7
Tricksta
Tricksta's Avatar
saw this?
Modifications
Old 12-29-2014, 07:19 PM   #8
iPaulll
iPaulll's Avatar
Originally Posted by Tricksta View Post
saw this?
I haven't seen that until now. I'm not exactly sure what that diagram is telling me.
Old 12-29-2014, 07:39 PM   #9
Tricksta
Tricksta's Avatar
Since your Trunk Light works I'm guessing you have a wiring problem. Test power and ground wires going to license plate bulbs.
Modifications
Old 12-29-2014, 07:42 PM   #10
Tricksta
Tricksta's Avatar
Do your reverse lights work?
Modifications
Old 12-29-2014, 07:49 PM   #11
RedRaven
RedRaven's Avatar
Drives: 2012 2SS M6 CRT
You have a broken ground or a wiring fault from the BCM, or possibly a failed BCM output.
Check F29 in the IP fuse panel. If it is blown you have other problems.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties
First real car: 1968 Malibu, '67 283, Canary yellow
RedRaven is offline   Reply With Quote
Old 12-30-2014, 09:04 PM   #12
iPaulll
iPaulll's Avatar
Reverse lights are in order. I'm going to check said fuse to see if that leads me anywhere
Old 12-30-2014, 09:21 PM   #13
13BRM2SSRS
13BRM2SSRS's Avatar
Drives: 13 Camaro 2SS Vert L99
Did you try inserting the led lights both directions?
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
13BRM2SSRS is offline   Reply With Quote
Old 12-30-2014, 09:22 PM   #14
iPaulll
iPaulll's Avatar
Yes. Still no dice.
