Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 12-31-2014, 01:05 PM   #1
treker31
Drives: 91 camaro rs 305 v8
91 camaro will not start
I have a 91 camaro RS 5.0L 305 V8. I have changed the spark plugs, rotor, distributor cap, and fuel filter. When I turn the key on, I hear the fuel pump hum. I have also reversed the fuel pump relays. All it would do is turnover, but it still won't start. It has been idle for about six months without being cranked, with seaform in the gas tank. What do I need to do in order for it to start again?
treker31 is offline   Reply With Quote
Old 01-06-2015, 10:38 PM   #2
Obsessive Camaro Disorder
Obsessive Camaro Disorder's Avatar
Drives: 69 Camaro and 92 RS
Have somebody spray starting fluid into the tbi. If it starts you have a fuel problem. If not, you have a ignition problem. Start there and if you have any more questions come back and I'll be glad to help.
Sorry I didn't see your post sooner.
There are 3 ways to do any project. Good, fast, and cheap. You can only choose two.
If it's done good and fast, it isn't going to be cheap.
If it's done good and cheap, it isn't going to be done fast.
If it's done cheap and fast, it isn't going to be good.
Obsessive Camaro Disorder is offline   Reply With Quote
305, 3gen
