01-04-2015, 05:36 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
I wish Chevy would finally get to DOHC (for us SC guys)
I'm insanely jealous of the huge intercoolers that the Ford guys have been able to run for decades now with the Ford DOHC engines. They just leave such a gigantic area in the valley to drop in intercoolers. I know there is some intense love of the LS engines....and they are certainly great engines...but I'd love to see Chevy get off the push rods and into the DOHC set ups.
Check out the size of the brick that Kenne Bell can fit in the Ford Coyote!!!!! I'm jealous... |
01-04-2015, 05:37 PM | #2 |
And here is the Camaro brick....damn push rods!!
01-04-2015, 05:39 PM | #3 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Easy fix, trade for a Mustang.....
The Bird is the word! |
01-04-2015, 05:56 PM | #4 |
Banned
Drives: Camaro Join Date: Mar 2013
01-04-2015, 05:59 PM | #5 |
Easy fellas. I came to Camaro from Mustangs. I wanted to give a Chevy a try. I'm not bashing the LS engines...just trying to create a technical discussion about the limitations of top engine intercoolers for us here.
01-04-2015, 06:03 PM | #6 |
There are other aspects of a pushrod engine that are more advantageous than a DOHC. Don't look for GM to drop it anytime in the near future.
01-04-2015, 06:05 PM | #7 |
That's true. I think top mount supercharging intercoolers are very low on the list of design criteria at Chevy. Although it always seems that all OEM superchargers seem to be top mount...
01-04-2015, 09:33 PM | #8 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
That's because it's more emissions friendly. One problem that comes to mind with having DOHC and even SOHC is cam swaps. At minimum you're buying 2 cams for SOHC and 4 for DOHC. Then there's the fact of timing it all. Everything has to be spot on so you don't crash the valves into the pistons. Lastly is head swaps. There is so much more involved with swapping heads. The benefit of having it is that there is no pushrod, so there's never a worry about a rod bending.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
01-05-2015, 12:07 AM | #9 |
Drives: 2014 1SS RS 1LE tvs2300 Join Date: Jun 2014
Chevy uses small superchargers in their cars. If you really want a huge blower cut a hole in your hood. I just hope Chevy never goes to overhead cams. I came from an EVOX, hell of a car, but it's overcomplicated and the drivetrain is crap. The coyote engine is a great engine, but there are too many people (consumers, engineers, etc.) that still want a pushrod engine. Rant over.
01-05-2015, 12:09 AM | #10 |
I knew this when I read your original post lol. Go turbo or centri, your issue is no longer an issue.
01-05-2015, 05:30 AM | #11 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
Chevy knows how to build them. They're building them now. Just in V6 form. Pretty bad assed little motor. 217 cubic inches (3.6L) sporting 305 hp. 11.5:1 compression ratio but still burns 87 octane fuel. It makes significantly more hp per cubic inch than the vaunted LT1 motor in the new C7 Vettes.
01-05-2015, 08:31 AM | #12 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Mercury racing has dohc heads for the LS motors already. Just do a quick Google search. The thing I hate about them is the timing belt! Sure cam swaps would be a breeze but think of the service intervals of a timing belt. Every 60k and I'm sure they will be like the ford's and take $1k in specialty tools to set everything up.
I'll stick to the PROVEN timing chain on our motors.it's nothing to see 2-3-400k miles on a ls motor. Just my 2 cents!
01-05-2015, 12:04 PM | #13 | |
01-05-2015, 01:33 PM | #14 |
