![]() Drives: 2015 ZL1 Coupe A6 & 2002 ZO6 Join Date: Apr 2014
LS9 Blower
What kind of boost is a LS9 blower capable of on a LSA engine? I have an opportunity to pick one up for a decent price from a buddy that is taking it off his ZR1.
Thanks |
![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Jess!!!!!!!!!!!!! You're Up. Lol
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
Calling jess. Are you out there. Lol.
![]() Drives: 2014 ZL1 M6 Join Date: Jul 2014
If you pass it up, let us know.
pleanty of folks on here would want it. Tony
2014 ZL1 M6
Bone stock, for now! 2001 Z28 M6 !cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB !4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners! 352rwhp and 366rwtq |
Following
#6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Boost is a measure of restriction. When I put the LS9 on my car it had a 427, radical camshaft, trickflow heads, oversize valves, long tube headers. It was a very good flowing motor so the max boost we ever saw with the LS9 was around 15 pounds. I'm guessing at 23,000 rpm it would make about 19 or 20 pounds on a stock motor.
The main problem with the LS9 is you have to have the Lingenfelter snout adapter to run it on a LSA motor. Those may be hard to find because it is my understanding that Lingenfelter stopped production of that snout when the Heartbeat blower came out because the Heartbeat made more power for less money. The LS9 is a little better blower than the LSA but unless you get it for next to nothing it is not worth the costs in my opinion to convert your system. It does not handle over-rev as good as the 1.9 does. When it gets to the rpm limit it hits a wall and gets so hot you have to back off. I say port the 1.9 and pulley it up, get bigger reservoirs and pumps and heat exchangers and when you max out the 1.9 then swap directly to the heartbeat.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#7 | |
Thanks for the info and advice Jessrayo! What are your thoughts on the 2.8 Kenne Bell? |
#8 | |
Speed Freak
With the other alternatives I just don't see that a KB is a good option on a Camaro when you consider costs. If real big power numbers are your goal, you would be better off buying the AGP turbo kit and selling the stock blower.
#9 |
![]() ![]() ![]() Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Good Thread. Thanks for the information Jess.
#10 |
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
What Jess said.
#11 |
What trackman said. Lol.
#12 | |
#13 | |
Jess, So, I ended up picking up this LS9 blower for a price I could not pass up. Now in search of a Lingenfelter snout...Haha. What kind of horsepower will this thing make on a built motor with the blower maxed out and possibly on E85 or Meth? What RPM is considered maxed (pulley combo)...23,000? Thanks |
#14 |
![]() Drives: 2013 Ashen Gray m6 ZL1 camaro Join Date: Nov 2012
I'm using a LS9 blower on my ZL1 m6 w/Lingenfelter snout and 700 hp package with a forged 376 ci motor. Blower pulleys 2.55/8.25 =21000 rpms on a LPE 93 octane tune. It made 752 rwhp /727 rwtq at 16 lbs of boost peak.
