Custom User Title
Drives: 2012 Camaro 45th Anniversary Join Date: Jul 2012
Boost gauge for convertable
I'm looking to buy a boost gauge, any suggestion ? I really like the pillar setup, but don't think they work on verts.
I have the SLP boost gauge that fits on top of the steering column . Looks like it came stock . Works great and blends in with the car .
![]() ![]() ![]() ![]() Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
I made one for a customer.
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Have you considered a Dashlogic unit? I have mine displaying boost on my HUD. Best thing about the Dashlogic is no install is needed other than plugging it into the OBDII port.
I also have the dash logic and it can replace a bunch of gauges . Very easy to use . That being said I still love the SLP boost gauge.
#6 |
I'm looking at the dash logic as well, it will show boost in an SS if you install the ZR1 MAP sensor. I still need a wideband with an output foe HPTuners, they offer an add on, but not sure how good it is.
#7 |
![]() Drives: 2012 2SS Convertible Join Date: Sep 2014
I just bought a Dash Logic unit from a member here. I had been looking for a nice solution for some meters. I had planned on getting the SLP steering column setup but really liked the ADM dashboard install. Also looked at Aeroforce which I liked a lot, but prefer using the standard displays. The fact that I can show custom parameters on the HUD and can create specific alarms, made me change to Dash Logic.
#8 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
| Tags |
| 2012, 45th, boost gauge, camaro, convertible |
