Old 01-06-2015, 07:25 AM   #1
biigtee400
Drives: 2011 Camaro SS M6
fuel system question
I have low compression 416 making 500rwhp, I have a f1a procharger coming with meth injection planning on making at least 800rwhp, and my question is should I put a duel fuel pump and volt booster from Ligenfelter or go with the squashs return line system for a few hundred more?
biigtee400 is offline   Reply With Quote
Old 01-06-2015, 07:34 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Definitely squash
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 01-06-2015, 10:23 AM   #3
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
Squash, hand down. Adding a BAP to any fuel system will shorten its lifespan. The reason you don't here about it a lot is because most people have already switched to an upgraded system.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 01-06-2015, 10:56 AM   #4
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Squash and be done with it!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 01-06-2015, 01:38 PM   #5
biigtee400
I agree thanks all. I'll post pictures when its in.
Old 01-06-2015, 05:49 PM   #6
united1
united1's Avatar
Drives: slpzl585vert.
Yep , for a little extra cash you might as well go with the squash and be done .
Thanks guys<img src=images/smilies/w00t.gif border=0 alt= title=W00t class=inlineimg />
united1 is offline   Reply With Quote
Old 01-06-2015, 06:01 PM   #7
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Squash or Fore return system. You put too much money in your engine to cut corners on what feeds it.Do it right the first time.
JMI is offline   Reply With Quote
Old 01-06-2015, 06:04 PM   #8
jrpxxii
jrpxxii's Avatar
Squash
Old 01-06-2015, 10:22 PM   #9
PwrAdikt
PwrAdikt's Avatar
Drives: 2005 silverado ss 2010 camaro ss
I love fore.
PwrAdikt is offline   Reply With Quote
Old 01-07-2015, 04:59 PM   #10
biigtee400
I looked up fore, I think I like it more, it comes with a high flow fuel filter and I like the options it gives you and doesn't have any core charge like squash.
Old 01-10-2015, 01:35 PM   #11
BoostedPrime
Banned
The Fore Innovation fuel systems are a piece of art. They perform very well and look beautiful. I am a dealer for them and ID injectors. I highly reccomend both. (I can offer good deals on both)
BoostedPrime is offline   Reply With Quote
Old 01-10-2015, 03:14 PM   #12
realsquash
realsquash's Avatar
Drives: Four Door Camaro
Beauty is in the eye of the beholder I guess. Talk to some people who have installed them and run them and see what they say. If you have any questions just send an email or give us a call.
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems
realsquash is offline   Reply With Quote
Old 01-10-2015, 03:43 PM   #13
BoostedPrime
Banned
True. Not knocking your system at all i have seen people with sucess using your kits. I personally like the fore myself
