![]() Drives: 87 Iroc 350, 2001 SS, 45th 2LT Join Date: Feb 2011
RS OEM HID Problems - Ballast
My drivers side headlight quit working about 2 weeks ago. I checked the fuses and the relay in the fuse box. The fuses were fine and I rotated the relay and the drivers side headlight still did not light. I thought it was the bulb at this point so I bought 2 D1S bulbs and installed them. The drivers headlight was still out. I now notice that when I turn the headlights on the bulb briefly flashes. I'm now thinking it's the ballast. I order a ballast from Ebay for $34 and install it by removing the front tire/wheel, inner fender well, and the washer reservoir. With the new ballast the headlight works great until today (about a week after I replaced the ballast). This morning when I go to start the car the drivers side headlight does not come on. After turning the headlight switch on and off a couple of times the headlight lights and stays on for my 45 min drive to work.
Anyone else have this kind of problem? I guess I got a bad ballast? Any other thoughts?
2012 2LT 45th Anniversary Edition ~ Solocus
![]() Delivered 9-29-2011 exactly 45 years to the day from the first 1967 Camaro showing up in dealer showrooms! |
Alamo City Camaros
Drives: 2014 2LT/RS 2014 2SS/RS/1LE Join Date: Aug 2014
Anyone having this problem ... just started having this problem with the 1LE, with the exception of the ebay ballast, mine is OEM.
CAI Intake, Borla Touring Axle Back, FOOSE Legend Wheels, Vertical Doors by River City Creations, Expel sidemarker Blackouts, GTS Headlight & Tail light Blackouts, Oracle Headlight Colorshift & Fog light Halo's, Engine Bay, Grill, Wheel ring & underglow lighting by RiverCity Creations, Hood & Deck lid murals by SC Airbrush & Designs
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I would blame the ebay ballast. There is a benefit to paying for OEM parts when it comes to electrical.
#4 | |
![]() ![]() ![]() ![]() Drives: 2012 1SS M6 IOM Join Date: Dec 2012
Sounds to me like your having problem with your ballast. Unless its OEM, I wouldn't put that cheap Ebay crap in my car.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
May be more expensive but some things you can't cut corners with
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
#6 |
El Duderino
Believe it or not Walmart usually has the best deal on genuine OSRAM (Sylvania) HID bulbs.
This one looks like it comes with the ballast. They frequently go on sale for around $50-$60. http://www.walmart.com/ip/Sylvania-H...D1SSZ/44410313
#7 |
Alamo City Camaros
I agree, my 1LE does have OEM parts, I wouldn't take a chance on ebay parts. I ordered an OEM ballast already. Just waiting for it to come in, it was about 158.00 and I thought that wasn't too bad compare to what the dealer will charge.
#8 | |
BUMBL Z
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
#9 | |
El Duderino
#10 |
BUMBL Z
25794777 I believe
