Old 01-09-2015, 08:23 AM   #1
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
13 ZL1 - Intermittent pop while turning.
Guys -
13 ZL1 with stock suspension, wheels, and tires. I have noticed recently that while making a sharp turn, I will hear a pop come from the front. I also noticed it while backing out with the wheel turned. Thought I hit something but nothing was around me. Both the passenger and myself will hear and feel it when it happens. The noise is intermittent so I'm not able to duplicate. I took it to the dealer for it previously and they could not duplicate but said they didn't find any issues after inspection.
Any ideas what i should be looking for or where I can go to get a good is inspection?
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 01-09-2015, 08:32 AM   #2
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
I had a similar issue with my headers hitting the passenger side frame rail when the engine torqued and turning left. I'd check for clearance there if that sounds similar.
Whos_Drivin is offline   Reply With Quote
Old 01-09-2015, 09:35 AM   #3
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Mine does it when backing out of driveway and only turning wheel to the right. But once in a while only.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 01-09-2015, 11:23 AM   #4
Iroc-ZL1
Iroc-ZL1's Avatar
Drives: 2013 ZL1 #505
mine does the same, I thought I was just crazy lol
Iroc-ZL1 is offline   Reply With Quote
Old 01-09-2015, 11:34 AM   #5
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Same here!!
owhite3003 is offline   Reply With Quote
Old 01-09-2015, 11:34 AM   #6
WookiesZL1
Drives: 13 ZL1 Vert M6
Same here,after sitting for a couple days. backing out of garage and first turn of wheel,POP! Like i ran over the garden hose and vehicle rolled on it but nothing was there. I only have 2500 mi so issue few and far between occurances.
WookiesZL1 is offline   Reply With Quote
Old 01-09-2015, 12:32 PM   #7
Splitter
Drives: '14 RRM 1LT/RS A6
http://www.camaro5.com/forums/showthread.php?t=390124
Splitter is offline   Reply With Quote
Old 01-09-2015, 01:10 PM   #8
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
I always thought it was stiction in the suspension or just a sticky sway bar mount.
Had all sorts of these noises in the back of my Z4M coupe. Always the sway bar. Had them n my Subaru STi. Always diff bind. In the ZL1, I just pretend it's a Miata caught under the real wheel.
boondocksaint is offline   Reply With Quote
Old 01-09-2015, 01:50 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
few clicks here as well...no worries, it seems to be normal
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-09-2015, 02:20 PM   #10
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
Same here when it is cooler outside. Back out of driveway, turn and pop. Warmer it does not. Most of the cars have this for some reason.
Nor Cal ZL1 is offline   Reply With Quote
Old 01-09-2015, 04:21 PM   #11
Camero5
Camero5's Avatar
I feel better I'm not alone. Started noticing it as it got colder out here. It's only happened 3 times and only happens when turned to the right so far that I have noticed.
Old 01-09-2015, 04:23 PM   #12
Camero5
Camero5's Avatar
Originally Posted by Splitter View Post
I appreciate the link. Doesn't sound like my issue since my car is DD and the noise is happening while driving and making a sharp turn or u turn. Recently happened backing out of a parking spot with wheel turned to the right.
Old 01-09-2015, 04:33 PM   #13
brian-nicola
brian-nicola's Avatar
Drives: 2014 ZL1
This sounds very close to what was happening in 2012 CTS v series. Excerpt from a post on that site:
Wheel Clicking
We acknowledge and regret that some CTS-V customers experience this "clicking sound" from their wheels in low speed, tight turn parking lot maneuvers. We've studied this phenomenon fairly extensively; it is the result of interface of the aluminum wheel to aluminum rotor hat configuration. We have released a technical service bulletin that prescribes a very high degree of cleanliness in the wheel-to-rotor mounting, and our experience to date is that the TSB, if followed exactly, is very effective in eliminating the noise.
Some customers had been concerned about this being a noise from brake system interference to the wheel under high steer angles. It is not. The noise emanates from the mounting surface of the wheel on the hat of the rotor at high steer angles. If you have this noise, the cleaning process and re-torquing is fully covered by your warranty at our dealership. If you choose to dismount wheels on your own, please follow the service bulletin pasted below and carefully follow the instructions on cleaning and torquing wheels.
GM has tested the integrity of wheel attachment on the CTS-V. The "clicking noise" is not indicative of any concerns or compromised performance in wheel attachment integrity, or in the wheel itself.
http://www.cadillacforums.com/forums...f-cooling.html
brian-nicola is offline   Reply With Quote
Old 01-09-2015, 05:52 PM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Who the hell can hear this clicking noise over the loud exhaust these cars have?
Mods:
