Old 01-09-2015, 08:41 AM   #1
JayV83
JayV83's Avatar
Drives: 2010 camaro 2SS RS LS3
what is everyone doing for boost and other gages
I am supercharging my camaro and i want a boost gage and air fuel gage....not sure how i want to get this done. Please post pics of your setups. Thankyou
2010 Camaro SS LS3 Kraftwerks Supercharger 594rwhp 9.5 psi Dynatech 1.875" Headers, Dynatech Highflow Cats, 3" Flowmaster, JRE Tune, More to come!!!
1970 GTO Butler built 474 stroker, Pump GAS
1987 Monte SS Healthy sbc 5 speed
JayV83 is offline   Reply With Quote
Old 01-09-2015, 08:46 AM   #2
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
ADM makes a nice top of steering column boost gauge. A lot of members are doing the mod in the air conditioning pod to the left of the steering wheel. Some are getting flat gauges to tape to the top of the steering column as well. You cold also remove the top center speaker trim, speaker, and rim and mount gauges up there through a gauge mount. Lastly, you always have the c-pillar mounting type, vendors on the site sell single and double mounts. Personally I would run ADM or anything from speed hut is good quality yet expensive. Most mechanical gauges are the same, if you are looking at electronic ones however, make sure you don't cheap out on quality.
DaFisch is offline   Reply With Quote
Old 01-09-2015, 11:07 AM   #3
NOTAV6
Drives: 2010 ECS Camaro SS
Having done piller pods and such on other vehicles was not high on my list for my camaro, so I did the slp steering column pod with the AEM Failsafe gauge (boost and wideband in one gauge) to keep a little more clean look
NOTAV6 is offline   Reply With Quote
Old 01-09-2015, 01:23 PM   #4
RankSS
Drives: 2010 Camaro SS
I have the Cobalt gauges. Fuel pressure and boost on the pillar and AFR on the SLP column pod.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 01-09-2015, 01:36 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
From top:
Aeroforce interceptor showing RPMs, Vac/boost
Aeroforce interceptor showing oil pressure and coolant temp
Eboost2 in AC vent showing vac/boost
PLX in SLP pod on steering column showing fuel pressure. It also will show AFR and will soon show oil pressure as well once I install the sending unit and lines.
I'm not totally sure why the vac/boost are off from each other. The aeroforce is drawing from the OBDII port (ZR1 MAP and configured tune for boost installed) which is taking readings from the intake. The eboost2 takes it reading from a vacuum manifold. I'm betting the aeroforce is more correct. You'll also notice the resolution on the aeroforce is higher and it constantly fluctuates so they might be closer than the gauges appear to show.
I was using the interceptors for fuel pressure but I kept blowing the sending unit and got tired of spending $70 every time. I've had no issues with the PLX stuff.
Old 01-09-2015, 01:38 PM   #6
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
You'll want a really good wideband for sure, but boost gauges you can usually pick whatever floats your boat. For the wideband though, I only trust AEM which is what I have on mine:
That's a solid wideband but it's the only one that I'll personally ever use.
ModBargains.com is offline   Reply With Quote
Old 01-09-2015, 05:02 PM   #7
JayV83
JayV83's Avatar
Im definately going to buy something of high quality... I am just worried about the visibility because visibility sucks in these cars to begin with lol.
Old 01-09-2015, 05:06 PM   #8
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Have same pillar. and gauges in them.
Old 01-09-2015, 05:35 PM   #9
JayV83
JayV83's Avatar
The pillar pod doesn't seem to restrict visibility too much...i may end up going that route.
Old 01-09-2015, 05:37 PM   #10
UF4LIFE102SS
Drives: 2010 2 SS
Yeah not bad.
Old 01-09-2015, 06:58 PM   #11
RankSS
I had a digital AEM AFR on my last car. The flashing numbers were very distracting.
I prefer the analog.
Old 01-10-2015, 01:21 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
What are you using for FI? If you have a blower that's set for XX pounds of boost, skip the boost gauge and get a fuel pressure gauge and a wideband O2. I have a boost gauge with my Maggie and it is absolutely useless.
AEM gauges and Autometer's pillar pod. Get a new clip for the pillar from the dealership before you install it so it doesn't pop back off.
Old 01-10-2015, 06:42 AM   #13
Unreal
Drives: 2006 Z06
Dashlogic works great, and I think they are available for all 2010+ camaros.
Blake, never blown a aeroforce fuel pressure sensor, but the instructions specifically state to always unplug it before unplugging the obd2 connector or it will blow, so I make sure to do that.
Nick
Corvette Z06 -1200ish rwhp
Old 01-10-2015, 08:36 AM   #14
stevieturbo
Drives: it changes
Whilst expensive..for a one gauge fits all, this is pretty damn good.
They will have a cheaper non-logging version available soon, the SDM-300 at a cheaper price.
I do still say it is a little expensive, but I seen it yesterday at the Autosport show here in the UK and the quality, visuals and general functionality and user interface on it is excellent. I was very impressed. The cheaper version isnt available yet though, they said another month or so.
It can connect to most aftermarket ecu's and also OBD ports, so should be able to display for almost any platform you want to use it with.
You'd still need a wideband controller to feed the info to it in order to display that on the dash
It's just a little larger than most sat nav units.
http://www.plex-tuning.com/products/plex-sdm-500
stevieturbo is offline   Reply With Quote
