3 issues/problems
1. Has anyone had experience cleaning the windshield fluid nozzles or are their any known techniques for camaros? Mine dont spray fluid at all so im assuming its from build up in the nozzle itself and i cant quite figure out how to dismount them without potentially breaking something.
2. Ive been getting that low tire psi warning on my dash and the service tire monitor system one as well. I check all four and their all around 36 as suggested. Its sporadic and random as far as which wheel it says is low. Ive taken it to discount tire and they said 1 sensor is bad but as stated the dash is saying otherwise. Is it possible the sensors are bad, the onboard computer is bad, or both? 3. Is their a prompt for when your headlights goes or is going out? Sometimes my front left headlight comes on with the daytime running lights on and sometimes it doesnt. However it always comes on when its switched to automatic off. Sorry if this has been asked already but all this happened all at once. Its a 2010 1ss if that matters. |
376 cubic inches of fun
1. If the nozzles are clogged, you should still hear the pump running. If you don't the pump, the problem is with the pump.
Do you have an after market radio? If so, the head unit sometimes affects the TPMS. Specifically, the Scosche head unit has been known to do this.
Everything is stock on the car and as far as the pump, is it a noticeable sound when its turned on
![]() Drives: 04 z06 yellow Join Date: Jan 2008
Just had the wiring harness shielded to the ac fan. Eliminated service tire pressure monitor
#6 |
![]() ![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
The washer fluid pump makes a very noticeable sound. It's almost like a buzzing sound.
#7 |
![]() ![]() Drives: 2011 ss Join Date: May 2013
Use a paperclip to clean out the nozzle
