Old 01-14-2015, 02:56 PM   #1
speedmon
Drives: C6 Z06
To GM: What I would like in the new ZL1
1. The Z06 (LT4) engine. They put it in the CTS-V, now I want mine.
2. The transmission in the rear. The car needs more weight in the rear and I don't need the rear seat anyway.
3. Less weight....minus 600-700 lbs should do it.
4. A downward sloping hood (like the 4th gens) so I can see the road instead of the hood.
That's it.....GM, if you build it, I'll buy it.
speedmon is offline   Reply With Quote
Old 01-14-2015, 03:11 PM   #2
Splitter
Drives: '14 RRM 1LT/RS A6
No trunk monkey?
Should be standard in all Camaros.
Splitter is offline   Reply With Quote
Old 01-14-2015, 04:01 PM   #3
brian-nicola
brian-nicola's Avatar
Drives: 2014 ZL1
Now my stomach hurts....LOL
brian-nicola is offline   Reply With Quote
Old 01-14-2015, 05:35 PM   #4
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Tranny in the rear? I am assuming you mean with the engine? The ZL1 is almost perfectly balanced now, why change it?
Via lightning from a large Hammer.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 01-14-2015, 05:55 PM   #5
96MrBass
96MrBass's Avatar
Drives: GM
Give about 60hp and a little diet and it would be just fine.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 01-14-2015, 06:06 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I'll just take the trunk monkey!
Mods:
Old 01-14-2015, 06:11 PM   #7
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
How about the LT4 with a 2.3 blower...or bigger...
Whos_Drivin is offline   Reply With Quote
Old 01-14-2015, 06:11 PM   #8
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Like the Z06, with a transaxel drive.
Old 01-14-2015, 06:11 PM   #9
Red Hot ZL1
Red Hot ZL1's Avatar
Drives: 2014 Red Hot ZL1 Vert. M6.
Transmission in the rear? Get a Carman Ghia, and a trunk monkey.
Red Hot ZL1 is offline   Reply With Quote
Old 01-14-2015, 06:58 PM   #10
speedmon
Drives: C6 Z06
Tranny in the rear....more weight.....I need more traction.
I short shift first gear all the time because 1st+throttle = wheelspin.
AWD would be awesome, so I could have a ZL1 GTR, but I know that would take GM another 800lbs.
ZL1s would be soooooo fast if they had traction.
Old 01-14-2015, 07:06 PM   #11
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
AWD ZL1 with 700 hp?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 01-14-2015, 07:20 PM   #12
Bizaro
Drives: 2015 Redhot 1LE
new zl1? there will be no new zl1
Bizaro is offline   Reply With Quote
Old 01-14-2015, 07:43 PM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
It took GM 40 years to bring back the ZL1........
What makes you think the ZL1 will come back with the 6thGen?
Mods:
Old 01-14-2015, 08:10 PM   #14
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
LT4 would be a likely candidate but I would guess not before GM brings out another ZR1 Corvette with a new engine. I doubt the Top Corvette and Top Camaro will have the same engine at the same time, especially in the beginning of the gen 6.
The Camaro will not have a transaxle like the Corvette.
(Just buy a Corvette if you don't want a back seat and want a more balanced car. Corvettes are nice cars and fast and they are Chevrolet and can be had for not much more than the current ZL1)...
The C7 Corvette gained a lot of weight over the C6. I doubt the Gen 6 Camaro will loose any weight at all over the Gen 5. (Most cars are getting heavier rather then lighter) Most of the speculation about weight lose has been on this forum. (Some of the same people who argued that GM would never make a ZL1 Camaro in the first place. They were very wrong).
Visiblity could be improved but not at the expense of making an ugly car.
IMO, GM could change the game forever if they made an AWD Camaro. It is 2015 and who says "muscle cars" have to be RWD anymore? Even with only 600hp and more weight, it could make the Hellcat look silly. Imagine 2-305 and 2-285 summer performance tires putting 600hp to the ground while the Hellcat struggles to put 700hp to the ground through 2-275 all seasons...
2013 ZL1 #7860 is offline   Reply With Quote
