![]() Drives: 2015 z28 sold Join Date: Dec 2014
First day at track....Need Z28 setup sheet
Hey Guys
I'm going to the track tomorrow. Can somebody post the GM performance setup sheet for our car? Its the one that gives alignment angles and brake bedding instructions.. Thanks, Mark |
KaBoom1701
Didn't you get that stuff when you bought the car?
http://www.chevrolet.com/content/dam...PREP_Final.pdf
Mods:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 C7 Z51 Join Date: May 2012
Well, some of the track-prep involves fluid and alignment changes (if you're inclined to follow), for which you're probably too late.
I personally think besides the guidance on alignment settings, there's not much to follow.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
#4 | |
He left me the yellow spring spacer tho. Just installed the camber plates this afternoon,...doing the alignment right now Last edited by MARKSTI; 01-16-2015 at 06:17 PM. |
Just did the alignment
The plates rock...max setting for the front gets 3.7 degrees camber..WOW Dailed it back alittle tho....since my rear adjustable arms aren't installed yet Ended up with 1.4 degrees rear camber/2.3 degrees front with 180# driver |
