Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 01-18-2015, 03:26 PM   #1
Chris P
Drives: 2012 V8 SS Yellow
tyre pressure sensor
I have a 2012 SS.
one of the tyre pressure sensors has gone down, I have a new one but, will it need resetting. Is this some thing I can do or if now where could I get it reset.
Chris P is offline   Reply With Quote
Old 01-19-2015, 02:13 PM   #2
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
Originally Posted by Chris P View Post
I have a 2012 SS.
It used to be on the 2010-11's you could do it yourself using the owners manual but after that they got smart and now you have to use a TMPS tool. The dealer can do it or tire shop. But since your in North London I would take it to the dealer. Here's a link to the manuals:http://www.chevrolet.com/owners/chevy-manuals.html#2010 Page 9-62 in the 2010 manual. It might work on yours. Also to Camaro5.
Baldman is offline   Reply With Quote
Old 01-19-2015, 04:39 PM   #3
pete-1le
pete1le
pete-1le's Avatar
Drives: 2013 Camaro 2SS RS 1LE
I have a 2012 SS.
I had an error TMPS on my 2013 SS a couple of weeks ago.
I've now bought a tool which is like an electronic handheld device which transmits a signal to the sensors in the valve stem.
If you can get yourself a tool, you put the car into relearn mode by holding the stalk button in whilst displaying the tire pressure menu on the DIC.
Select yes on the relearn option.
Horn sounds twice to acknowledge relearn mode is active.
You then transmit to the drivers side valve stem, the horn acknowledges again, then do the front passenger side, rear passenger side and finally rear drivers side. The horn will sound twice again at the end of the process.
If you're ever near Birmingham, message me and you can use my tool :-)
pete-1le is offline   Reply With Quote
Old 01-23-2015, 05:20 AM   #4
Chris P
Pete, where did you get the tool? Do you have a euro apec or American import. I have been told they are on different frequencies.
Old 01-23-2015, 06:22 AM   #5
MLAZ1990
Drives: 2012 black camaro 2LS
You gotta use the TPMs tool to resync them...
MLAZ1990 is offline   Reply With Quote
Old 01-23-2015, 06:42 AM   #6
pete-1le
pete1le
pete-1le's Avatar
I bought the tool from another UK owner, the previous owner had a UK car, my car is a USA import, the tool works on both. It also says proudly made in the USA, so it's not specific to EU. As long as the sensors themselves are genuine GM then it should be fine.
WEBSITE 1le.uk | FACEBOOK facebook.com/pete.1le
Old 01-24-2015, 10:43 AM   #7
Chris P
so if you had wheels for summer and wheels for winter, you have to reset every time you change the wheels. Where can I get a tool from
Old 01-26-2015, 04:45 PM   #8
pete-1le
pete1le
pete-1le's Avatar
The sensors are unique so yes every time you swap wheels you would need to relearn your car to the new wheel sensors. I guess the way these sensors work with the relearn process involved, ensures that GM are programming the wheels for the intended car and not another car parked next to it, lol.
My tool is made by Orange Electronic, USA.
http://www.orange-electronic.com/en/...rolet_all.html
Give them a call and make sure you're buying the correct one.
Next time I'm in the garage I'll take a photo of it if you want to be sure before your buy.
Another option might be to start another thread outside of the 'UK' area and ask if someone is willing to sell one to you.
Pete
Old 01-27-2015, 08:59 AM   #9
pete-1le
pete1le
pete-1le's Avatar
Hi Chris,
I can confirm that my tool is an Orange Electronics and the model number is EL-50448
New GM Tire Pressure Monitor Sensor TPMS Activation Tool EL-50448 Relearn Reset
http://ebay.com/itm/121530887060
Regards,
Pete
Old 02-26-2015, 06:20 PM   #10
DNAudus
DNAudus's Avatar
Drives: Bumblebee Camaro SS
Hi guys, I had my wheel refurbished recently and for some reason they couldn't re use the valve. They kept the sensor for me but told me I'd have get a new valve to attach it to.
I called Chevrolet in Cambridge and they said they had to order the sensor and the valve at the same time costing £110. Does anyone know if you can just get the valve and how much it would cost?
Cheers,
Damian.
DNAudus is offline   Reply With Quote
Old 02-28-2015, 06:43 AM   #11
RickGM
RickGM's Avatar
Drives: 2013 SS V8 L99 Magnusson Heartbeat
Probably said it needed replacing coz they'd effed it up. Try a Pm to Jules1200. He's had wheels refurbished. £110 is bad news.
UK Camaro Owner. One of a few.
RickGM is offline   Reply With Quote
Old 02-28-2015, 11:21 AM   #12
jules1200
Drives: Delorean DMC12, Camaro SS
Yeh I'd say they've messed sumat up. Mine had no issues at all.
jules1200 is offline   Reply With Quote
Old 02-28-2015, 05:53 PM   #13
DNAudus
DNAudus's Avatar
That's a pain in the bum. They did a really excellent job of colour matching the alloy and they've done one of my other cars with no issues at all. Fail! :'(
Old 02-28-2015, 08:16 PM   #14
L7EWB
L7EWB's Avatar
Drives: 2014 2LT RS
PM'd you @DNAudus
L7EWB is offline   Reply With Quote
