Old 01-19-2015, 04:16 PM   #1
2ssrsvert
2ssrsvert's Avatar
Drives: 2013 2SS RS BLACK CONVERTIBLE
Convertible Gauge Pillar
Has anyone been able to find a gauge pillar for a convertible. I have been looking and all of them say non convertible models.
if not any ideas would be appreciated as I need to do a (afr,Boost,Fuel Pressure) gauge in my convertible.
2013 Black 2SS RS Convertible, TSP 2" headers, rotofab CAI, Maggie tvs2300 w/ OD cog pullies and 3.6, Catless, Jet MAF Sensor, 238/244 cam, Cnc Heads, Roller Rockers, Flowmaster Outlaws, Monster Twin Clutch, Squash pump, ID1000 injectors, AlkyControl dual nozzle meth. Tuned by Vengeance racing
749 rwhp
2ssrsvert is offline   Reply With Quote
Old 01-19-2015, 05:03 PM   #2
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
No one makes one. I fabricate them, and have one in line now for a customer. I am not particularly quick at getting them done, as it's kind of a side thing, so I'm not trying to sell you one, just stating why I know that there isn't one available. There is only room for two gauges on a convertible pillar, because of additional attachment points as opposed to a coupe.
2012LS3VERT is offline   Reply With Quote
Old 01-19-2015, 07:37 PM   #3
2ssrsvert
2ssrsvert's Avatar
what would be my options then all I can find is a steering wheel column mounted one and the twin ADM digital gauges. any other ideas out there. I am not fond of mounting one on the column and wish the look of the ADM set was a lil more up to par.
749 rwhp
Old 01-19-2015, 07:42 PM   #4
2012LS3VERT
One fits in the left A/C vent with a plate, but that is just one. That is currently where my wideband is, I use the torque pro app through my OBD port to show boost and IATs. I believe you can see the wideband in the A/C vent in this pic.
Old 01-19-2015, 08:38 PM   #5
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
I mounted the Diablosport Trinity in the windshield and used that as my gauges. Now I have a Haltech, and if you can mount a Windows based tablet, you can run the cable to the tablet, pick whatever gauges you want to display, and also make tuning adjustments too.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 01-20-2015, 09:15 AM   #6
2ssrsvert
2ssrsvert's Avatar
where did you get the pillar pod from . I cant find one anywhere that will be compatible. also read somewhere the reason they don't make one is because of an airbag in the pillar, I could do a 2 gauge and do the gauge in the vent like you did,
749 rwhp
Old 01-20-2015, 09:20 AM   #7
2012LS3VERT
The one in the pic is the one that I mentioned that I fabricate. That is a pic of a test fit prior to me shipping it back to him. I haven't built the one for my car yet, as I have another one coming for a customer. There IS NOT an airbag in the convertible pillar.
Old 01-20-2015, 09:27 AM   #8
2ssrsvert
2ssrsvert's Avatar
ok thanks for all of your help you would think someone would make this seems to be a lot of interest after searching the web for one the last few days.
749 rwhp
Old 01-20-2015, 09:54 AM   #9
14ZL1M6
14ZL1M6's Avatar
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6
Does someone make the vent plate to purchase or did you fabricate that yourself?
Thanks
14ZL1M6 is offline   Reply With Quote
Old 01-20-2015, 08:52 PM   #10
SuperchargedStealth
Thanks
You have to get one that's fabricated. I tried looking for one a while back and found nothing.
Old 01-20-2015, 09:09 PM   #11
2012LS3VERT
Thanks
I make them also, I have them water jetted from lexan, then paint them from the backside.
Old 01-22-2015, 11:22 AM   #12
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
here is a convert gauge made out of an Autometer coupe pod.......
RBD is offline   Reply With Quote
Old 02-03-2015, 07:36 AM   #13
BaronConcepts
BaronConcepts's Avatar
Drives: Camaro
Hi, my company just launched gauge pods that fit in the speaker grill cover for models with Boston Acoustic Premium sound system. We have both 2 and 3 gauge options in different color combinations. Check them out on www.BaronConcepts.com
Our Facebook.com/baronconcepts also has some more photos of them installed
BaronConcepts is offline   Reply With Quote
Old 02-03-2015, 08:23 AM   #14
14ZL1M6
14ZL1M6's Avatar
Do you have any plans to design a pod like this with two gauges and a tach? I would be interested in something like that. Or, even just with a tach?
Thanks
