View Poll Results: Who should I get brake rotors from for my ZL1?
Brembo (Duh.) 16 72.73%
Wilwood (the next brembo?) 1 4.55%
StopTech (the name says it all!) 2 9.09%
EBC (the euro stuff) 1 4.55%
other (named in post) 2 9.09%
Voters: 22. You may not vote on this poll
Old 01-19-2015, 10:30 PM   #1
James4086
Drives: Black 2017 ZL1
New Brake Rotors
Ok, I checked summit and they said they didn't have anything that matched the front rotors on my ZL1 with the slotted and dimpled option. I'd like to change but I haven't purchased these before. (I've installed them before on a friend's car, but I haven't purchased rotors before)
Has anyone done this before?
Where is the best place to look?
Who has the best stuff?
Is there a set of numbers I could use to look up what I'm looking for? (ex, with tires I could just say 315/35/ZR20, do brakes have a similar code system?)
Also, are the SS rotors the same as ZL1, I thought they were?
James4086 is offline   Reply With Quote
Old 01-19-2015, 10:38 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Brembo's....all others are crap....
Mods:
Old 01-19-2015, 11:24 PM   #3
Joe P
Drives: 01 Camaro SS 12 ZL1 Camaro
www.brakeworld.com
Joe P is offline   Reply With Quote
Old 01-20-2015, 06:04 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Im going to try EBC which are slotted and dimpled. The listing in their catalog isn't for a Camaro ZL1 but a Cadillac CTSV. I got this idea from a magazine. If they suck, I will go back to the stock style.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-20-2015, 12:43 PM   #5
James4086
Thanks Joe P, I believe I've found a winner.
Old 01-20-2015, 02:59 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Racingbrake has a rotor that is a little lighter and is slotted. They are expensive but seem to work well, mine are cracking at the end of the slots but over all show a lot less cracking than the stock brembo rotors did with extreme heat.
http://www.racingbrake.com/Two-piece...1-F-p/2160.htm
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
brake, rotor, slotted, zl1
