Old 01-21-2015, 03:31 PM   #1
Powellbr
Drives: '99 Mitsubishi Mirage de coupe
Handling after upgrading suspension
Hey guys, as the name says, I was wondering how the handling and ride feel is after upgrading the suspension and adding a Hotchkiss strut tower brace and sub-frame connectors from Granetteli Motorsports. I'll be going with BMR rear toe rods, trailing arms, lower control arms, bushings, adjustable sway bars, and motor mounts with the aluminum bushings. Here are links to all:
Control arms: http://www.bmrsuspension.com/?page=p...023&superpro=0
Bushings: http://www.bmrsuspension.com/?page=p...172&superpro=0
Toe rods: http://www.bmrsuspension.com/?page=p...483&superpro=0
Trailing arms: http://www.bmrsuspension.com/?page=p...041&superpro=0
Sway bars: http://www.bmrsuspension.com/?page=p...164&superpro=0
Strut tower brace:http://www.phastekperformance.com/20...ace-500076.htm
Sub-frame connectors:http://www.phastekperformance.com/20...ace-500076.htm
Motor mounts: http://www.bmrsuspension.com/?page=p...d=75&catid=325
Powellbr is offline   Reply With Quote
Old 01-21-2015, 04:25 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks for your support. I'm sure you will be happy with our products and the way they ride & handle. I'm not a fan of that Granatelli kit - too thin of tubing spread over too large of an area and trying to do much. Our Subframe Connectors are a lot less expensive and stronger.
What will you be doing with the car? I
Old 01-21-2015, 04:58 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Good setup for sure, but I'd skip the under-bracing. The 5th Gen chassis is already very rigid and the bracing will basically only be adding on extra weight.
What year is your car and what will you be doing with it?
Best regards,
Tyler
888-308-6007
Old 01-21-2015, 05:48 PM   #4
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
I do not think any of the road course guys use any under carriage bracing, and many have not added a strut tower brace. $0.02
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 01-21-2015, 05:50 PM   #5
Dan@Hotchkis
1
Drives: Whatever is available!
We made ours out of elliptical aluminum tubing for those exact reasons. The added chassis rigidity without the added weight. The chassis exhibits a lot of flex under launch and cornering loads and our connectors reduce that flex pretty dramatically.
Dan@Hotchkis is offline   Reply With Quote
Old 01-21-2015, 08:22 PM   #6
Powellbr
Itll be used as a combo dd & drag car,both strip & street ,also should mention ill be puttin in a 10-point chromoly cage
Old 01-21-2015, 08:23 PM   #7
Powellbr
Thanks for the info about granetelli, I'll look @ yours when I get a moment
Old 01-22-2015, 09:55 AM   #8
Powellbr
So I've taken a look at the hotchkis braces and they look a whole hella better than the granetelli.
Old 01-22-2015, 04:01 PM   #9
Powellbr
With probably 1500+ horsepower, how's the ride gonna be? Is it gonna be rough or almost like stock (or as close to stock 1500+ horsepower can be) but extremely athletic? I'll be using the firmest setting on the sway bars also because I know that'll make a difference at higher speeds & in the corners.
Old 01-22-2015, 04:27 PM   #10
Dan@Hotchkis
1
Can't rightly say. I don't know of or have any personal experience with cars using our product with that much power. Most of the higher power cars are in the 400-600rwhp and benefit quite a bit from our bracing.
As to the sway bar settings, they are adjustable to handle a variety of track surfaces and driving styles/preferences. Going full max right out off the bat may cause the vehicle to have an unfavorable handling characteristic, or it might be perfect.
Old 01-22-2015, 04:44 PM   #11
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
FMT solid subframe bushing are a nice addition..
Here is some pictures of some of the parts and the build i just completed
Nighthawk89 is offline   Reply With Quote
Old 01-22-2015, 05:11 PM   #12
Powellbr
Ok, also I got to lookin on PhastrkPerformance and was wondering if it'd be possible to use the ARH floor plan brace, the hotchkis sub frame braces, and the G5 front subframe brace all together?
Old 01-22-2015, 09:46 PM   #13
Dan@Hotchkis
1
I'm not sure. You'd want to ask that seller/installer if they have mixed and matched those pieces before. We generally don't do cross manufacturer fitment unless it's a non-competing aftermarket component, like a supercharger or exhaust.
Old 01-23-2015, 03:23 PM   #14
Powellbr
Ok, so I got to looking at the parts and an image of the undercarriage (still waiting to get my Camaro sadly) and it looks like you could use the G5 brace with the hotchkis set 'cause the G5 stiffens the front subframe. Still waiting to hear back from ARH on whether or not they've had anyone do it and if they've had any success doing it.
