Old 01-21-2015, 05:36 PM   #1
SixSpeeder
SixSpeeder's Avatar
Drives: 2015 Camaro SS
OEM Tune - NPP Exhaust vs Standard Exhaust
Not sure if this has been discussed, but is the factory tune the same for cars equipped with the dual mode exhaust? I understand that the mufflers are pretty far downstream and after the very restrictive cats, so I'd assume that it has the same tuning as a standard SS and just slightly adapts to the slightly increased flow.
Anyone know the answer?
2015 Summit White Camaro 1SS 6-Speed: NPP Exhaust, RS Package, Short Shifter, Nav
SixSpeeder is offline   Reply With Quote
Old 01-21-2015, 05:49 PM   #2
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
In my build thread I have a dyno of a 14' ss with npp maybe you can compare that to another.
LSXBumblebee is offline   Reply With Quote
Old 01-22-2015, 06:11 PM   #3
SixSpeeder
SixSpeeder's Avatar
I've heard that the NPP exhaust adds power verified on a dyno in other threads, but I'm curious if the factory software (map) is exactly the same for cars equipped with the dual mode exhaust, or whether Chevy took advantage of the slightly increased flow at upper RPM and altered the stock map. I guess nobody knows..
Old 02-04-2015, 04:50 PM   #4
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I see no reason why it would be different, on the corvettes the NPP is supposed to add an extra 5hp, this is pretty minimal and wouldn't affect how the engine runs.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 08-08-2015, 02:43 AM   #5
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
Does anyone know this answer? sorry for bumping old thread but I need to know please.
Dubscamaro is offline   Reply With Quote
