![]() Drives: 2013 Ashen Gray 2SS Join Date: Dec 2014
Hi everyone, I recently purchased a 2013 2SS with 13k miles on it, previous owner installed magnaflow cat back exhaust and a cold air inductions intake. Anyways, I've noticed that while I'm accelerating, everything sounds normal until I keep my foot down at a steady position, normally between 1k-2k RPMs, the engine goes into a ridiculously deep drone that vibrates the whole car. If I competely let off the gas while in this "drone", the car continues to accelerate for about half a second after my foot is off the gas. Right when I start accelerating a little harder, it pops out of the drone and sounds normal. By the way I've ran 93 octane since I purchased the car. Is this normal for camaros? Do I need a fuss pull? Or it could it be something worse? Thanks
Drives: 2015 Redhot 1LE Join Date: Feb 2013
Are you sure this isnt just drone from the after market exaust system? you can usually hear it at cruising speeds on the highway. And youre saying your car still pulls after you take your foot off the gas pedal? Thats definitely not good!
Maybe post video? |
![]() ![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
I know precisely what you're talking about. Drone is a common issue with aftermarket systems.
You have a few options to consider. The first is adding J pipes on to the existing aftermarket exhaust. There is a thread on this somewhere on the forum and I believe a DIY if you have a welder and cutting torch. You can put the stock exhaust back on. You can buy an aftermarket exhaust that already has a J pipe system. |
![]() Drives: 2SS 45TH,gfx,blade spoiler,h grille Join Date: Jan 2010
active fuel management? do you have an automatic?
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
No way would I ever go back to stock exhaust on my L99.
| Tags |
| 2ss, camaro, drone, fuse pull, magnaflow |
