Old 01-24-2015, 08:30 AM   #1
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
Anyone that has done a CAI, question about the windshield washer tank?
I am looking to do a cold air intake, and I see that most if not all of them encloses the windshield washer inlet. For anyone that has done a CAI, did you leave the tank inlet alone? Did you purchase a Washer Fluid replacement kit?
What about a intake scoop?
Pro's and Con's of either?
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 01-24-2015, 09:21 AM   #2
LBJ
LBJ's Avatar
Drives: 2012 camaro 1LS. M6
I have not moved my tank & it's no big deal to add washer fluid but I don't drive mind a lot .I have noticed a better sound and performance ... I can't respond about using the scoop I hope this helps
Mods..mrt v2. Cai intake v max throttle body. 20% windo tint & RX catch can Gianna 20in rims nitto 555 & afterburner tail lights RS halo head lights & gm heat extractor 4 pack gauges & panted heritage Grille & zl1rear sproler t5 splitter custom head rest
LBJ is offline   Reply With Quote
Old 01-24-2015, 09:30 AM   #3
SliverSurfer
Drives: Summit White 2014 1LT
+1
I have the CAI Inc system and the lid Covers the washer bottle,which isn't a big deal...I keep a torx driver in my glove box. I haven't done the washer bottle replacement either, but have been thinking about it only if I do the scoop...which I'm still thinking about myself.
So, in short, I didn't do the washer bottle relo or the scoop. Lol
SliverSurfer is offline   Reply With Quote
Old 01-24-2015, 09:30 AM   #4
dmginc
dmginc's Avatar
Drives: In Circles
i didnt relocate my WW tank nor have I have added the scoop. it isn't too hard to add washer fluid tho. the cover for the CAI brand intake comes off fairly easy.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 01-24-2015, 12:11 PM   #5
NYCamOwner
"Katy"
NYCamOwner's Avatar
That's kind of what I was wondering, how easy is it to fill with the CAI around it.
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
Old 01-24-2015, 12:12 PM   #6
camaro1350
camaro1350's Avatar
Drives: 2013 Camaro RS 1LT, 6M
You all should do the scoop I relocated mine washer bottle however. Put in the scoop not hard to do and you get better airflow. No sense of having a CAI if you not letting air in right.
camaro1350 is offline   Reply With Quote
Old 01-24-2015, 12:16 PM   #7
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
I purchased a Cold Air Inductions cold air intake and not too long afterwards did the Air Scoop using the Apex air scoop and windshield washer relocation kit. I have to advise you that while I love the setup and the butt dyno gains, it is a royal PITA to install. It took me about 5 hours to do it mostly because I am really anal about doing things correctly. It does involve removing your drivers side wheel and fender liner and using a Dremel to cut a notch out of a plastic part directly behind the lower grill. The horn bolt that the scoop attaches to was nearly impossible to remove and I almost dislocated my shoulder trying to get it loose with a socket wrench. I positioned my WW inlet outside of the CAI box as I wanted nothing in the way of the air flow going to the filter. See my install pictures below. Good luck. It is a great mod, just give yourself plenty of time to do it and be persistent. I was going to give up several times but pushed through.
pinoyscorpion951 is offline   Reply With Quote
Old 01-25-2015, 02:33 PM   #8
djcfuzz
Do somethin fun every day
djcfuzz's Avatar
Drives: 2012 45th V6 RS M6
The stock WW tank is enormous and in the direct path of airflow. I pulled mine and put in a Rotofab tank which fits nicely up top behind my CAI cold air intake box. Looks good too. I also installed the air scoop, it couldn't hurt.
djcfuzz is offline   Reply With Quote
Old 01-25-2015, 02:38 PM   #9
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
I had it both ways, and with the air scoop it woke up the CAI. I had my horn bolt replaced in 10 seconds, and I unscrewed it with my hand. I made my own replacement washer bottle; the OEM one holds about a gallon of juice that is un-needed weight.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 01-25-2015, 02:39 PM   #10
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
+1.....i actualy didnt do the scoop initially, but i did it a year later with the Washer bottle relocation kit and it ran better to me....or at least thats what my butt dyno said!
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 01-26-2015, 05:24 AM   #11
NYCamOwner
"Katy"
NYCamOwner's Avatar
Thanks for the responses everyone, some things to think about when I do this. I was leaning towards doing all 3 at the same time rather than doing the CAI first, and then having to change it later.
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
Old 01-27-2015, 02:31 PM   #12
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Volant makes one with a pre-made hole fits over the washer fill
kmarshall2121 is offline   Reply With Quote
Old 01-27-2015, 04:03 PM   #13
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
First of all thank you for choosing our CAI for your vehicle, I am confident that you will be very happy with your purchase
Secondly, although many people run the scoop/washer bottle relocation kit and are very happy with it, don't feel like not doing it will cause you grief. The lid comes off in seconds and is held in place with 3 spring loaded fasteners, and I'm guessing you wont be filling your washer fluid all that often anyways. So for the few times a year you have to add some fluid, taking the cap off the washer fluid will probably take nearly as much time as taking the lid off of your CAI
If you have any questions, feel free to let us know, thanks!
Sales @ CAI Inc is offline   Reply With Quote
Old 01-27-2015, 05:35 PM   #14
Ryanbabz71
Ryanbabz71's Avatar
I added a scoop to mine and removed the washer tank. I do t use the wipers so the washer fluid is pointless. Weight savings
Ryan
Ryan
