Old 01-27-2015, 11:40 AM   #1
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Dish soap on car.
hey guys I've read and read to no avail. People say dish soap is bad for paint or it doesn't matter. I want to load my foam gun up but not sure if I should use dish soap or automotive soap. Really just want it as clean as possible so I can polish it and glaze/wax it.
Knockoutpie is offline   Reply With Quote
Old 01-27-2015, 11:45 AM   #2
Nvincent4708
Drives: N/A
Dish soap removes old wax. I'm sure others will say don't do it, but I have in order to strip old wax and such.
Nvincent4708 is offline   Reply With Quote
Old 01-27-2015, 11:47 AM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
It's just real harsh, some dish soap can really remove a decent amount of wax from the car if its already polished, so its good that your going to wax it after your done.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-27-2015, 11:49 AM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Dish soap is wonderful for what you're wanting to do. What you don't want to do is use dish soap after you're done waxing,as it will degrade and remove it.
Dish soap ok for strip wash, not for regular wash.
[B]
Old 01-27-2015, 11:52 AM   #5
Knockoutpie
Ya all I want to do is completely remove everything on the vehicle besides paint of course. Then give the whole thing a nice polish, glaze, and then a good wax.
Trying to remove all those swirl marks that the dealer didn't remove.
Old 01-27-2015, 11:58 AM   #6
1KillerSS
1KillerSS's Avatar
I hate swirl marks, I can run a wheel and when I was detailing cars as a kid, I never left swirl marks. its a 3 to 4 step process with a wheel. If it were me I would take the car back and have the swirl marks taken out. That painters helper or person that detailed, didnt do their job. To be honest you will always have to have wax on it to keep from seeing the swirl marks, without wax will always be there. They need to finish that last glaze.
Build thread
Old 01-27-2015, 11:59 AM   #7
Knockoutpie
The Dealer said they polished it, TWICE! I just think they didn't do a good job or took long enough, or applied the right glaze and wax after. So I'm going to take a shot at polishing glazing and waxing. I don't think it will be difficult. I've achieved some progress in spots doing it by hand. But my porter cable is coming in on a few days and I think I'll do great then. How often is good enough to polish? How often do I want to do it a year? After every wash or a few times a year? I know it levels clear coat so I shouldn't do it too often right?
Old 01-27-2015, 12:07 PM   #8
1KillerSS
1KillerSS's Avatar
I would only buff till its right, then just keep it clean with a clay bar when needed.
first is a rough polish heavy grit
second is a medium polish
third is a very fine grit polish
Fourth Then there is a glaze or a finesse and that's done with a sponge type pad, not wool.
After that I wax it with an orbital. That's how I did it when I ran a detail shop as a kid.
Build thread
Old 01-27-2015, 12:19 PM   #9
Knockoutpie
Can I glaze with an orbital or no?
My thoughts were polish
Glaze with no. 1 speed and then wax on 1 speed
Old 01-27-2015, 12:24 PM   #10
1KillerSS
1KillerSS's Avatar
I am sure things have changed by now, but 17 years ago the product I used was heat activated, that's why you used the fine sponge pad. You literally glazed the clear. I would bet that you can find some products that are out today that just may help you, and an orbital is better than nothing. Couldn't hurt.
Build thread
Old 01-27-2015, 01:09 PM   #11
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Yes, you can. Anything you can apply by hand, you can apply with a D/A and get similar or better results.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 01-27-2015, 01:14 PM   #12
Knockoutpie
Haha sorry for questions but what's a D/A?
Old 01-27-2015, 01:15 PM   #13
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Abbreviation for Dual Action Polisher(synonymous with Orbital Polisher), like your Porter Cable(PC).
Old 01-27-2015, 01:24 PM   #14
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
In general you should use a good quality car wash when you want to wash with soap. If you want to wash your car, then if it were me I'd wait until I can get a good car wash solution (along with the proper wash cloths, etc.) before washing the car.
Others say dish soap is good for stripping (actually you need a dedicated polish to completely strip wax), but I've never really been big on dish soap for any car wash application short of scrubbing my tires. Good luck.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
