Old 01-27-2015, 04:58 PM   #1
Goingfast
Goingfast's Avatar
Drives: 2015 ss camaro
Check engine light
Okay so i have had 3 check engine lights come on and they are all p0442 which is evap. And i have brought it to the dealer every time that it has came on. And this is the third time they did a nitrogen test ans there were no leak and they also replaced the vent valve. Thise did not handle the problem. What else might it be?
2015 1 SS/RS Camaro. GM fogs with RGB LED'S. Oracle Halo rings powered by Night owl. BMR 1.4" drop, . K&N intake. Mrr 228's with Nitto 275/315 Motivo tires. Z/28 whicker bill and Front splitter.
Goingfast is offline   Reply With Quote
Old 01-27-2015, 05:58 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Could be as simple as a gas cap, could be purge valve, vent valve, evap hoses, charcoal canister, could even be the computer.
TommyTheCat is offline   Reply With Quote
Old 01-27-2015, 08:09 PM   #3
Goingfast
Goingfast's Avatar
Yeah its hard to say but they did a nitrogen test. And it isnt the gas cap because it doesnt come on after i gas up. It usually comes on when i start it up and i put the car in gear. Lol
Old 01-27-2015, 10:45 PM   #4
L99CAMA2011
L99CAMA2011's Avatar
There is a TSP I had done in which they replaced the module I think. They had to drop the fuel tank , took them like 4 hours.
Old 01-28-2015, 12:01 AM   #5
Goingfast
Goingfast's Avatar
Yeah its still under warranty so im not too worried about it.. Hopw they can figure it out and it be right the time.
Old 01-30-2015, 02:19 PM   #6
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
I had exact code with when I scanned it it showed up 3 times on my scanner,,, this happened right before storing it for winter ,, so its not fixed yet, mine is 2010
bmbbl be is offline   Reply With Quote
