Old 08-26-2009, 07:34 PM   #1
ambjocky
June 6, 2009
ambjocky's Avatar
Drives: 2010 Camaro
A\C "now not cooling properly"
I received my car on June 4, #11488. Up untill now I have not had any problems. Yesterday when I got into my car,I turned the A|C to max cold, adn it seemed like it did not cool like it had been. It worked fine on our trip to Florida from here in Oklahoma. It eventually cooled down so I though it was the heat 100 degrees! This morning when I got into it it did the same thing, eventually cooling down, the outside temp was only 80 degrees. I called the dealer, and they stated there was not a service bulletin out for them yet (at least that problem.) He said to bring it in if it does it again. Anyone else had this problem yet? I have read about the drain plug issue.
2SS-RS SIM Black Interior
RotoFab CAI
MBRP 3" Cat Back
Vector Tune
ambjocky is offline   Reply With Quote
Old 08-26-2009, 08:10 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
my car did the same thing, On Sunday i drove back from LV and it seamed that the fan was not moving any air so on Monday at the dealer's it was fine and did not do a thing.
Old 08-27-2009, 10:56 AM   #3
camaroguy
MJ is finally home!
camaroguy's Avatar
Drives: 2010 CGM 2SS/RS Camaro M6
I had the same problem with the fan would stop blowing air seeming like it was bogging down or something. Took it to the dealer- Ended up being low on refrigerant from the factory. All is good now.
camaroguy is offline   Reply With Quote
Old 08-27-2009, 11:00 AM   #4
Scott@Bjorn3D
Guys check the drain thing. Turn your car on, turn AC on Max. Turn fan on high, max sure recirculate is turned off. Look under your car after 5 minutes of running this way and see if it is dripping.
IF NOT Dripping. Take it to dealer and have them look up the service bulliten on the AC drain. It could be the collapsed groumet issue. The AC unit is now filling up with water and soon your fan will be throwing water around inside your car.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-27-2009, 11:20 AM   #5
2SSRS@Gen5diy
Scott my car runs a river under the car if all is ok, the day that it did not work got home and no water under the car, Got home at 2 pm and at 7:30 pm there was a lot of water under the car.
Old 08-27-2009, 12:09 PM   #6
victorredrs
Drives: 2010 victory red rs
My car was doin the same thing when I first got it. Now all seems to work well but the vent next to the drivers door is at least 15 deg warmer but the thing that confuses me is that the two vents next to each other in the center are 10 deg different. I guess I will call the dealer to see if this is normal. Oh just to let everyone know they almost replaced everything that has to do with my ac.
victorredrs is offline   Reply With Quote
Old 08-27-2009, 02:00 PM   #7
ambjocky
June 6, 2009
ambjocky's Avatar
Drives: 2010 Camaro
My A\C is making plenty of water and it is draining fine. It just does not seem like it is cooling as quickly as it used to. It is now taking about 10-15 min. for it to start cooling? Guess I will take it to the dealer.
RotoFab CAI
MBRP 3" Cat Back
Vector Tune
Old 08-31-2009, 12:25 AM   #8
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
I can keep ice cubes in my car with the ac.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 08-31-2009, 01:52 AM   #9
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
may have a blend door motor issue
firestone_ss is offline   Reply With Quote
Old 09-08-2009, 08:42 PM   #10
victorredrs
I took my car to a different dealership and there is a problem and TAC cannot fix it. They thought it was the evaporator so they changed it. I am supposed to get a call tomorrow hey are going to get someone from Chicago come out and look at it. They tell me it is a gm engineer. I will keep all posted to the OP did you ever find out why yours was blowing warm?
Old 09-18-2009, 08:50 PM   #11
Warr3nc
Drives: 1969 Camaro
Here is one bulletin for a no flow air condition:
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that the blower produces little to no air flow through the HVAC vents with the AC on. This concern typically occurs during extended highway drive times. This may be caused by an evaporator freeze condition.
Recommendation/Instructions:
Check for signs of the compressor overheating. This can be identified by inspecting the label on the AC compressor itself. If the AC compressor experienced an overheat condition, the label on the compressor will have air bubbles underneath the label lifting it from the compressor. If this is found, replace the AC Compressor and flush the AC system using the ACR2000.
For all vehicles with suspected AC evaporator freeze condition, REPROGRAM the Remote Heater and Air Condition Control Module with the latest calibration in TIS2WEB that states "New calibration to prevent evaporator freeze".
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
And this is one that GM put out for AC not cool:
Condition/Concern:
Some customers may comment that their AC does not appear to blow cold enough. This could be due to selecting the incorrect setting from the HVAC controls.
For Max AC operation, follow the instructions below.
1. Temperature must be set on the MAX position rather than being placed to the blue dot, There is an additional detent to the left of the blue dot labeled MAX.
The temperature dial should be set on the MAX setting for best AC performance.
2. HVAC air-outlets are set to vent position (the face logo only- top button on left dial).
3. Blower is set to medium or higher (twelve o'clock position or greater).
4. Be sure the Snow Flake LED is illuminated.
Warr3nc is offline   Reply With Quote
Old 09-20-2009, 06:08 PM   #12
whitemiket
Drives: 2010 ABM 2SS Camaro
I am having a similar issue. I drive a business trip that is roughly 200 miles and I have used my 2SS 3 times for this. First and second times, no problems. Third time, temps in the mid 80's and the stretch where it went out on was 70 and I keep it pegged on 75 with CC and it blows the A/C half way down the stretch. I felt water on my arms and then no cool air. I went to my dealer and the compressor is blown and they will do the new programming on the car on Friday. I have had a LS2 vette and an H2, and this is typical GM crap. Love the car, and its a keeper, but GM puts parts in their to fail on purpose IMO. Luckily its now and not 2 years from now.
whitemiket is offline   Reply With Quote
Old 09-23-2009, 10:52 PM   #13
josh1147
Delivered 29June09
Drives: Early Order Camaro
Got a call from my dealership late today saying that I should come in for the "A/C reprogram" bulletin....
but I've not had a single problem with it, have done several long trips, high external temps in Georgia, highway driving, city driving and have never once had a problem with the A/C so I'm a bit hesitant to let them touch my baby.
josh1147 is offline   Reply With Quote
transmission cooling line leak-from factory SS4PK Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 21 12-23-2021 05:57 AM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
Pavillions Saturday August 15th - It's Cooling Down! az5thgen USA - Southwest 17 08-17-2009 10:48 PM
Cooling fan noise SamsinSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 06-17-2009 12:15 PM
SS Brake Cooling Slots Rodrunner Cosmetics and Lighting Modification Discussions 9 12-10-2008 03:32 PM
