#1 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
New Supercharger kit available from Kraftwerks
Kraftwerks contacted us some months ago about a new kit to be hitting the market and provided me with a prototype kit to test fit, and write the calibration for.
The kit is going to be priced very attractively for the budget minded hot rodder. Fit and finish is nice. Installation is Easy. Performance is impressive given the size of the Charger. Test subject is our local customer Jason 2010 Camaro LS3 with Dynatech Headers and cats no other mods. The calibration was a breeze and put down 522 RWHP 465 RWTQ at a subtle 6.3 psi boost on 93 octane. We have a smaller supercharger pulley to test to make up for the boost loss with the headers and high flow cats we will be testing as well. Rotrex Supercahrger head unit. Cast aluminum powder coated brackets Aluminum washer bottle and aluminum radiator overflow tanks black powder coated. Comes standard with Cog Drive system no belt slip ever. ATI Super Damper standard Large 4 inch thick front mount intercooler 3 inch intercooler piping black powder coat. Silicone couplers throughout. Bypass valve with option to recirculate or open to atmosphere Washable air filter Self contained oil system with oil cooler and reservoir, 50,000 mile oil change intervals ZR-1 injectors ZR-1 map sensor NGK TR7IX plugs All included in the kit Has a nice little whine to it. Drives like stock until you get on it. Over all we are impressed with the quality of this kit. More to come stay tuned with JRE
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
More pics during the install.
![]() Drives: 2010 camaro ss l99 Join Date: Apr 2013
estimated price?
TSP vvt-1 cam, Headers-catless xpipe, Knn intake 417/422 Nitrous 100 wet shot 520/585 Racestar super 94 17x4.5/17x9.5 highest trap to date 120.6mph 12.0@spinfest. rage |
That is a decision that Kraftwerks will make I have made a suggestion and they liked it.
All I can tell you is it will be priced very competitively and below other similar offerings. Ted.
Sounds good to me, been looking for a cheaper option that still retains quality craftsmanship. nitrous is fun but time for a dedicated power adder
#6 |
![]() Drives: 2010 camaro 2SS RS LS3 Join Date: Nov 2013
That is my car it is being tested on. I drove it today and I am very pleased with the outcome. It makes a nice little whine/ whistle while driving. Ted and his team did a fantastic job installing the kit and answering all of my questions.
2010 Camaro SS LS3 Kraftwerks Supercharger 594rwhp 9.5 psi Dynatech 1.875" Headers, Dynatech Highflow Cats, 3" Flowmaster, JRE Tune, More to come!!!
1970 GTO Butler built 474 stroker, Pump GAS 1987 Monte SS Healthy sbc 5 speed |
#7 |
I just can't wait till the weather clears up
#8 | |
![]() ![]() ![]() Drives: 2013 1SS Camaro and a truck Join Date: Apr 2011
What power level is this supercharger capable of? Does this supercharger get heat soaked? Sorry for the beginner questions.. |
#9 |
Scavenging affect of the headers increases airflow which creates less back pressure which lowers boost a little bit. They are long tube headers. Centrifugal superchargers don't generally get heat soaked since they aren't bolted directly on top of the engine. They do generate some heat but nothing compared to a pd blower or turbo
#10 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Is there room to grow on this kit or is it close to being maxxed out since you said its smaller than other competitors? And why does the torque seem low compared to other FI cars?
2010 Camaro SS LS3 - No Modz
#11 |
The torque is very comparable to other centrifugal kits making tha same boost. Changing the pulley should bring the boost on sooner and make more torque. There is room to grow as we can spin this thing faster. How much? That is to be found out.
#12 |
Eh, that'll happen
Interesting....will subscribe.
#13 |
Boost is a product of restriction, when you get rid of the restriction of the factory manifolds and cats by adding long tube headers and high flow cats you pick up power and increase air flow across the cylinder head lowering the boost reading, typically about 1 psi.
#14 |
interested
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
