![]() Drives: 2010 Victory Red Camaro SS/RS LS3 Join Date: Oct 2010
Est. Hp boosted with meth/nitrous
I currently have the 2.9 whipple with the 4'' pulley tuned by jannetty racing and in the spring I'm going to pull the trigger and install Jannetty racing rough idle blower cam with more boost and hopefully make around 700rwhp. On top of that I'm looking to install the alky control meth kit, I'm curious on the pros and cons of running that set up on a stock bottom end and what kind of rwhp numbers are we talking. I'm not to familiar with the alky control meth kit but I've heard nothing but good things. Thoughts of maybe putting a small shot for the track as well? or thats playing with fire?
ARH 1 7/8 headers catless 3'' long system, Whipple sc 4.00 pulley 9 lbs boost, msd boost-a-pump, CAI intake, Pfadt coilovers, toe links, trailing arms, solid cradle bushings, sway bars, Forgestar CF5 19x9.5/19x11, M/T et street II radials
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
On a stock motor you'll be fine with the meth and Whipple at 700rwhp. Adding N02 to that mix will be a risk.
The Whipple is more than capable of making 700rwhp with a cam and proper fueling Good luck! |
![]() Drives: 2013 Camaro SS Coupe L99 Join Date: Feb 2013
Check out Aquamist for your meth, also look at DSX tuning. Just my .02
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
The methanol will help bring down the iats that the whipple makes
Too much is never enough!
Stock bottom end is good for 900whp, and if your going to do meth, get the big tank. So far I love it.
