Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 01-29-2015, 11:06 AM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up ITS BLACK NOW!!! FAST 102 Intake for 2010-2015 SS Camaro "Check out the New Look"
Thats right FAST has changed the color from the White to the New Black
Check out the New look
So if you were turned off by the Old Color, then Black should be a No Brainer when upgrading your Intake. Blends in much better with the engine compartment and doesnt look dirty under the hood like the Old White.
http://www.phastekperformance.com/20...xr-146102b.htm
Sales@Phastek is offline   Reply With Quote
Old 01-29-2015, 11:09 AM   #2
MRREVINTO7
Drives: 14 1Le --14 chevy ss sedan 07shelby
like the old color better is it still available
MRREVINTO7 is offline   Reply With Quote
Old 01-29-2015, 11:19 AM   #3
Sales@Phastek
Hi MRREVINTO7
You might still be able to find some. But FAST no longer is making them in white and we can not get them anymore. All we have now are the Black version.
Old 01-29-2015, 11:33 AM   #4
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I like that color better than the grey I have...
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 01-29-2015, 06:05 PM   #5
LTRS777
LTRS777's Avatar
Drives: 2014 Saleen 620 White Label #14-011
Looks incredible. Any numbers for the 5th gen ls3s?
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors,
ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs,
BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned!
573WHP/557WTQ @ 10psi.
Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708
LTRS777 is offline   Reply With Quote
Old 01-30-2015, 02:22 PM   #6
Sales@Phastek
LTRS777,
The numbers are the same as the previous intake, which is about 15-20rwhp with just the intake bolted on. The only difference with the new intake is the color, they only offer the Black now.
Where this intake really shines is when you add a cam, headers, supercharger, and other supporting mods. The intake is larger then the factory piece allowing more air to flow and move through to the cylinder heads.
Hope that answers your questions. Let me know if you have any others.
Thank you,
Ricardo
comp cam, fast 102, phastek
