![]() Drives: '10 2SS/RS Join Date: Jun 2014
P0301 issue
Started my car and it immediately started to shake and shut off. Tried to start it again and I had to push the gas pedal while it was turning over to get it to start. The idle was really rough and the car would shut off if i let off the gas. Not sure what happened, the car was parked and had no signs of anything failing. I checked spark plugs/wires and checked for a vacuum leak but no signs of anything wrong. Also noticed a bad knock in the engine and all the dash lights were blinking with a Service stabilitrak message displayed. I scanned it and im getting a P0301 error code (cyl 1 misfire). Do you guys have an idea of what it could be? if i cant figure it out i'll take it to the dealer on Monday.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
My apologies regarding your engine code concerns. Although I understand your displeasure, it's great that you'll be proactively reaching out to your dealer for an official diagnosis. Keep us in the loop and updated on your service visit. If necessary, I can contact the dealer's Customer Experience Managers if you have additional questions. We'll look forward to your updates .Kindly, William R. Chevrolet Customer Care |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
How long has it been sitting since you last started it with no problems
It was sitting for about 10 hours. I drove to a hospital and when I left it started acting up
If you checked the wires and spark plug, most likely culprit would be a bad coil or a clogged fuel filter, improper fuel pressure from fuel pump. It will definitely need a dealer to properly diagnose.
#6 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
if its only misfiring on cylinder 1 its probably something specific to it. Not likely to be a fuel pump or filter since that would affect all cylinders.
Probably coil, maybe a wire, injector, or plug. Compression is possible but unlikely |
#7 |
Yep, I would guess. Bad coil first, hope he comes back and tells us what it is, lol
Some have had some coil problems, but have not heard too much about injectors going bad this early |
#8 |
Took it to the dealership and they said I needed a new engine. The service writer believes it was a cam issue and it blew my motor... I'll have more details in the upcoming days
#9 |
#10 |
#11 |
Update as of this morning:
The motor isn't destroyed like they thought at first. It ended up being a stuck valve |
#12 |
If they are changing the one valve that stuck, do yourself a favor and have a conversation with the mechanic and see what it will cost to have him replace ALL of the lifters to the new design and tell them to double check all the valve timing and adjustments when they replace the lifters. It will come back working better then new. May cost you a few bucks but if your going to keep the car it will be worth it Just a thought. Or you can think about a Cam ! And upgrade the beast as well.
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#14 |
from what the mechanic said this is pretty common. He thinks its most likely from a bad down shift. He also said they see a lot of corvettes in for the same reason. most likely a 6-3 downshift
