Old 01-30-2015, 08:32 PM   #1
jake2212
jake2212's Avatar
Drives: none (yet)
Bigger coolant resovoir
Anybody know a good bigger coolant resovoir that will work with the CAI intake? Looking to get something better than the tiny one it came with
jake2212 is offline   Reply With Quote
Old 01-30-2015, 09:28 PM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
The coolant reservoir is on the passenger side of the car. The windshield washer reservoir is the one by the CAI.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 01-30-2015, 09:30 PM   #3
jake2212
jake2212's Avatar
Drives: none (yet)
I know, but what im saying is a few companies have made bigger resovoirs that go right behind the air intake, and i was wondering if any company made one that fits next to a CAI intake.
Old 01-30-2015, 09:35 PM   #4
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Oh, gotcha. Does your car run hot? I havent seen too many complaints on over heating with a Maggie.
Old 01-30-2015, 09:40 PM   #5
jake2212
jake2212's Avatar
Drives: none (yet)
after a few passes at the track cooling is a bit of an issue
Old 01-31-2015, 10:25 AM   #6
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
here is mine,,, holds a gallon,,, it is a roto-fab
bmbbl be is offline   Reply With Quote
Old 01-31-2015, 12:01 PM   #7
jake2212
jake2212's Avatar
Drives: none (yet)
How does it attach?
Old 01-31-2015, 12:27 PM   #8
bmbbl be
bmbbl be's Avatar
Originally Posted by jake2212 View Post
How does it attach?
it attaches on the rod /bracket that is on the car already... on the tower brace
Old 01-31-2015, 02:49 PM   #9
jake2212
jake2212's Avatar
Drives: none (yet)
Could you take a pic please? Wanna see if it would fit with my CAI box in there
Old 01-31-2015, 03:42 PM   #10
bmbbl be
bmbbl be's Avatar
a pic of ??? mine is installed already
Old 01-31-2015, 05:01 PM   #11
jake2212
jake2212's Avatar
Drives: none (yet)
Yeah like a pic of it installed from the top. Much appreciated
Old 01-31-2015, 06:16 PM   #12
old motorhead
Drives: Maggie blown LS3 vette
A bigger tank won't help much when it's all said and done. Maybe stave off the hot temps very temporarily, but that's about it. When that extra coolant is heated up, you simply have more hot coolant that needs cooling. You're much better off trying to upgrade the heat exchanger and trying to aid air flow through said h/e. You can do some good with a bigger/better h/e along with a higher volume coolant pump.
old motorhead is offline   Reply With Quote
Old 01-31-2015, 08:03 PM   #13
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
^^^^^^^ What Old Motor Head said. I've run an extra two gallon reservoir and dual pumps and bigger heat exchanger and meth with only mediocre improvements under high ambient temp conditions. The bottle neck in cooling the iats lies beneath the Maggie....the brick intercooler. You will still add about 30 to 35 degrees of temp increase at the finish line to the starting IAT temp. You have about three choices to significantly control the IAT's.
1. Run in cooler weather using some of the mods above
2. Install an ice chest and pump....PITA but it does work
3. Chiller unit utilizing the car's A/C system
Just livin' life
2SSCAMARO is offline   Reply With Quote
Old 02-01-2015, 10:47 AM   #14
BoostedPrime
Banned
Drives: 2010 Camaro SS
Shoot me a text 832-630-8231 or pm
My intake air temps stayed below 40 degrees the whole night while doing pulls and making 1000 on the dyno.
BoostedPrime is offline   Reply With Quote
