Old 01-31-2015, 06:25 PM   #1
DarKnightZ
DarKnightZ's Avatar
Drives: 2012 SS Black Camaro
Check Engine Light came on after cleaning Intake.
Hello all, I was just cleaning out my Volant cold air intake (came with the car when I bought it) and I decided to just dust it out.. well I did, put everything back how it was and now my check engine light came on.. did I do something wrong or do I just need to reset something? Thanks
DarKnightZ is offline   Reply With Quote
Old 01-31-2015, 06:46 PM   #2
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Check and make sure you didn't accidently pull off one of the PCV hoses from the engine. If you did you are introducing unmetered air into the engine throwing the CEL.
Have you had the code read?
The Bird is the word!
Old 01-31-2015, 06:51 PM   #3
DarKnightZ
DarKnightZ's Avatar
Yea I double checked everything, tightened everything.. no I haven't had it read yet.. i'll go get it read later today though
Old 01-31-2015, 06:57 PM   #4
Angrybird 12
I take it you didn't add any oil to the filter?
Old 01-31-2015, 07:03 PM   #5
DarKnightZ
DarKnightZ's Avatar
No sir I did not.. I just cleaned it up and put it back..
Old 01-31-2015, 07:05 PM   #6
Angrybird 12
Next step is get the code read. Then go from there.
Old 01-31-2015, 08:22 PM   #7
DarKnightZ
DarKnightZ's Avatar
Um, well the remote start doesn't work.. I've made a big mistake..
Old 01-31-2015, 08:45 PM   #8
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
disconnect the battery for a few minutes, then try again.
Old 01-31-2015, 08:47 PM   #9
DarKnightZ
DarKnightZ's Avatar
Oh well in just went away.. I went to the store, tried the remote start and it worked and the CEL went away.. weird..
Old 01-31-2015, 09:58 PM   #10
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
The remote start will not work when the CEL is on. That part is normal.
thiggin2 is offline   Reply With Quote
Old 01-31-2015, 10:40 PM   #11
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
You can still get a code reading if it hasn't been too long, it will be a pending code.
And yes, remote start will not work whenever there is a check engine light on.
TommyTheCat is offline   Reply With Quote
Old 02-01-2015, 01:19 AM   #12
MLAZ1990
Drives: 2012 black camaro 2LS
Go to autozone and they can read it for you
MLAZ1990 is offline   Reply With Quote
