Old 02-01-2015, 06:40 AM   #1
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Trick for Drying MM Incredimitt
I have been doing this for a while now and it works well for me.
After you have washed the mitt, before placing it in the dryer on low heat, flip it inside out.
I run one cycle in my dryer on low heat, when the inside (which is actually the outside now that the mitt is flipped) is fully dry, flip it back and the outside is lightly damp. Now I have clean mitt which will air dry in about an hour.
I'm not heating up the microfiber so I can't damage it, and I don't get any lint from the dryer, plus the mitt gets fully dry so I don't get any mildew while in storage.
To elaborate on the flipping process, point the mitt with the open end away from your body, use your 2 index and middle fingers to stretch the spandex on the open end, use your thumbs to work the mitt from the base inside out, when your halfway there is a cloth "handle" which is sewn on the inside, gently pull and it pops right out.
Joe M 2012 2SS is offline   Reply With Quote
Old 02-01-2015, 10:46 AM   #2
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
I just got mine in the mail and haven't washed it yet. I'll definitely try this!
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 02-01-2015, 12:39 PM   #3
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Do make sure to wash any microfiber or wash media before you use it for the first time.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 02-01-2015, 01:13 PM   #4
scandata
scandata's Avatar
That was going to be my next question. Is it OK to use plain laundry detergent (I know NOT to use fabric softener)?
Old 02-01-2015, 02:23 PM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I wouldn't. Spend the cash and get some microfiber detergent. It's not worth the risk when you're spending big $$$ on towels.
[B]
Old 02-01-2015, 04:01 PM   #6
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
This !
Laus Deo
charlietuna is offline   Reply With Quote
Old 02-01-2015, 04:31 PM   #7
scandata
scandata's Avatar
OK, I'll get some then. Any suggestions? I also got a Dry Me Crazy towel, which I haven't washed yet either. Is it OK to wash them together with the same detergent?
Old 02-01-2015, 04:32 PM   #8
CamaroDreams07
Drives: Slow V6
You can wash all your microfiber together. I use Blackfire Microfiber detergent
[B]
Old 02-01-2015, 05:37 PM   #9
Joe M 2012 2SS
Drives: 2012 2SS
Corey at Car Pro did tell me when I purchased my MM stuff that you can use any detergent that is Free/Clear, MM recommends using micro-restore, so that's what I use.
I'm sure the Blackfire will work just as well as CDO7 has had his MM towels longer than I've had mine.
Old 02-11-2015, 08:01 PM   #10
Joe M 2012 2SS
Drives: 2012 2SS
Just added a video, hope this helps.
