![]() Drives: convertible Join Date: May 2014
Need help with fuse box 13 vert. Need a hot ignition off for a LED scanner
Im putting in a scanner and some LED strips, and Im having trouble branching the lead off the fuse box. The scanner has to be an active hot ONLY when the ignitions off, then it has to cut when the vehicle is started. I checked all the fuses and pretty much all of them are hot all the time.
The other thing is I have a dash led kit id like to install so its works with the door lamp. Unfortunately, whats really weird is this new camaro doesnt have any floor lights. I though that was really weird cuz Id usually just tap off those or cut them out completely. If anyone has any experience in this please let me know. I might need some sort of relay box I can get from autozone The Varad instruction book isnt much help. Because it generalizes the connectors, but I did read somewhere you have to connect it to a "Negative ground when the ignition is off" fuse. So if any of you camaro experts know which one of my fuses is grounded when off then Id love to know cuz I cant find it anywhere. Thanks |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
For my scanner light I tapped into the side marker lights this way they went on only when the sensor on the top of the dash went off, for the footwell lighting their are a few options, the stabiilitrak button has a yellow wire you can tap into and under the drivers side gray wire(I think) you can tap into. Mine is a 2011 so not sure if there were any changes
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
Whats the sensor on the dash? And is it active when the car is off and not active when its on?
I swung the lead from the dome light to activate the led strips so they work with the door now. I gonna attach 2 neon bars to the mirror and run that off the dome too. Hopefully it wont overload the fuse. But light bar and leds take almost no voltage so I should be okay. Just gotta fix the scanner now |
#4 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
![]() ![]() Drives: '12 2SS/RS 45th vert, '14 2SS/RS Join Date: Nov 2013
For a hot while ignition off circuit, check circuit 52 in the under hood fuse box.
#6 |
#7 | |
My Dream Car
correct I only wanted mine to run at night so when the sensor for the lighst went off my scanner and grill lights would come on
