Old 02-01-2015, 01:28 PM   #1
Scott@Bjorn3D
1996 Trans Am, is it worth it?
We are going to drive a 96 Trans Am with 93XXX mile on it. The guy is wanting 7900.00 for it.
Was that a good year for the cars? Outside does not look to bad. I do want to see it up on a rack and have the techs at the dealership look it over.
Scott@Bjorn3D is offline   Reply With Quote
Old 02-01-2015, 03:29 PM   #2
silkrckt
silkrckt's Avatar
Drives: 2017 Garnet Red 1LE
Seems a little over priced. I would rather look for an LS1 car 99 or later. Should be close in price with similar miles. Superior engine. I'd stay away from 98's. For comprision, there was 2002 WS6 in my area for 12k with 60k on it.
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60'
Old Camaro --- 94 Z28 Vert-- Miss it.
silkrckt is offline   Reply With Quote
Old 02-01-2015, 06:54 PM   #3
Muscle Car Memories
Muscle Car Memories's Avatar
Drives: 2015 Camaro 1SS,6 Speed,NPP Exhaust
Little bit over priced....
Muscle Car Memories is offline   Reply With Quote
Old 02-01-2015, 07:06 PM   #4
IOMCamaroSS
#PrimeCamaros
IOMCamaroSS's Avatar
Drives: IOM '10 Camaro SS
I would say it's AT LEAST a couple grand over priced..
instagram: @IOMsupersport // @PrimeCamaros
IOMCamaroSS is offline   Reply With Quote
Old 02-02-2015, 08:32 PM   #5
Fish-man
Drives: too many to say!
I bought a 95 Formula with original red leather seats back in 2009 for 5500... same mileage as that one.
still have that car... LT1s can be a little finicky with the optisparks (mine has not been an issue)... LT1 is HELL to put headers on and change plugs.
Fish-man is offline   Reply With Quote
Old 02-15-2015, 10:08 PM   #6
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
I agree with the rest. About $2,000 over priced.
zr1chris is offline   Reply With Quote
Old 02-15-2015, 10:36 PM   #7
dcpatters
Drives: 2015 Camaro SS 1LE
So true. Had a 95 Z28 and replaced the opti-spark twice. Prefer the LS1's 98-02. Much better motor.
dcpatters is offline   Reply With Quote
Old 02-18-2015, 04:54 PM   #8
RMarion
Drives: 2002 SS 6sp
You can buy the 98-02 with the LS1 for about the same with those miles. I have a 2002 SS with 51k miles and I'll sell it for $11k if your interested. Mobile AL. IMO the LS1 is a big improvement.
RMarion is offline   Reply With Quote
Old 02-19-2015, 08:01 AM   #9
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
run Hooker Longtubes. slip fit #1 primary, easy to install.
and you can run an LTCC (coil on plug) conversion for the optispark to eliminate the failure mode and only use the optical pickup portion.
Optispark... 60% of the time it works every time.
I piss excellence
and fart awesomeness
Old 02-19-2015, 09:00 AM   #10
Fish-man
didn't know about the Hooker LTs... but the headers I bought were JET coated - brand new Stainless Works, for a severe discount from someone that never got around to installing. Had to jack up the motor to install the pass. side. Had to remove starter too. Getting the orig stuff out was a pain. (including EGR/A.I.R)
Fall of '12 I did a minor overhaul including head removal... the 2nd time installing the headers wasn't too bad. At the time, I considered the coil on plug deal, but its expensive, so I just put on a new cap and rotor. Runs fine. I decided, that since I was getting the 5th gen, not to spend more than needed on the 'bird.
showin' off:
Old 02-19-2015, 09:26 AM   #11
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
Way overpriced for an LT1....you can buy LS powered Firebirds for around that price
And to give you an idea....
Here's a 1996 Chevy Camaro Z28, 60k miles, LT1 - $6900 - only about 40 miles from you...
http://www.cars.com/vehicledetail/de...3145/overview/
DevilsReject97 is offline   Reply With Quote
Old 02-19-2015, 01:31 PM   #12
CamaroSpike23
Truth Enforcer
showin' off:
shoulda replaced your motor mounts while you were doing the headers. helps a lot.
thats one thing that I've found causes the most hassle with 4th gens is the motor mounts are worn and the engine sags 1-2 inches from stock height and makes it a pain to install headers.
the other benefit of the Hookers is you don't have to disconnect the steering linkage to install them.
I think I paid like $350 shipped to my door for mine. bought them used off a guy and sold them for $300 when I got rid of my 94Z after 40k miles on them
the LTCC conversion can be pricey, but a lot of that was in the brackets and coils. you could buy a set of used coils for ~$100.00 and the module/harness was like 3-400. I got mine used (back when it was a wiring monster, newer versions use the stock LS style coil harness and 2 main wires).
I do remember a couple sites that showed you how to make your own harness and module on the cheap ~$150 in parts depending on availability as well as how to convert the "octopus" version to the "coil harness" version.
The other thing to consider with the LTCC kit is that it eliminates the failure point of the opti by only utilizing the optical pickup portion of it and moves the spark creation to the individual coils, thereby eliminating the creation of ozone within the housing which corrodes the contacts and causes failures.
It also eliminates contamination of the opti if the water pump fails and drips on the opti.
in addition to the LTCC kit, there is the Delteq kit
http://www.delteq.com/opti_design.htm
which uses 4 coils instead of 8 using the "negative spark" technology.
I piss excellence
Old 02-19-2015, 02:52 PM   #13
Fish-man
Yup did the mounts too.
Old 02-20-2015, 08:32 AM   #14
CamaroSpike23
Truth Enforcer
well damn... lol
I piss excellence
