Old 02-03-2015, 12:38 PM   #1
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
E85 results
Hey guys,
I, along with many of you, are patiently waiting for Squash to release their 'new' returnless fuel pump. Assuming that it finally comes out relatively soon, I wanted to know what kind of HP bump that I should expect from the conversion of E85 alone. I understand that the 105 octane allows me to create more boost, but what can I expect if I stay at my current psi level of 9.5? I'm not convinced that I want to keep adding more boost and I want to see if waiting for this pump even makes sense if I'm going to stay at my current psi level?
Thoughts. Thanks!
Magnacharged L99, 3.4 pulley, 9.5 psi, CAI Inc cold air intake, ID-850's, ZL1 pump with ADM FPCM, MT 305/45R18 DR's, 17x4.5 Race Star front skinnies, Stainless Power LT 1 7/8 headers & off-road pipes, BMR rear suspension goodies, JRE Super tensioner, JRE race scoop, Borla S-type and tuned by Jannetty. 11.08 at 124.5 mph with a 1.62 60' is my PB to date.
11syn3rgy is offline   Reply With Quote
Old 02-03-2015, 01:36 PM   #2
Bo White
Bo White's Avatar
~40rwhp
You get to add timing from the octane but you also get a cooling effect.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-03-2015, 01:45 PM   #3
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Originally Posted by Bo White View Post
~40rwhp
That's kinda what I thought. Just wanted to make sure I wasn't missing anything. Thanks
Old 02-03-2015, 01:54 PM   #4
Bo White
Bo White's Avatar
Depending on the quality of the E85 you will be adding ~10* of timing over 93 pump tune.
Totalled:
Old 02-04-2015, 02:28 AM   #5
Anythingfast954
Drives: Camaro ss rs/m6
Is it worth it for a daily driver knowing you'll burn 30% more fuel?
I don't drive far at all. Gym,and when I go to the track once a month.
I'm trying to learn more about this in our cars.
Anythingfast954 is offline   Reply With Quote
Old 02-04-2015, 08:39 AM   #6
LTRS777
LTRS777's Avatar
Drives: 2014 Saleen 620 White Label #14-011
If youre not far, its basically 1.50 race fuel, at the cost of some mpg. Its amazing imo. Does anyone have a write up on what's needed for our systems to handle e85? Or can it already? Typically the only issue with e85 is that itll eat up your fuel setup if its not designed to handle heavy ethanol setups (theres typically a big fuel system difference between flex fuel type and non flex fuel systems).
Lots of good information here: http://en.m.wikipedia.org/wiki/E85
Read through octane and performance and similar
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors,
ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs,
BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned!
573WHP/557WTQ @ 10psi.
Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708
LTRS777 is offline   Reply With Quote
Old 02-04-2015, 09:15 AM   #7
Anythingfast954
I wonder what needs to be replaced to be safe running it for a long time.
Fuel pump,injectors,supply/return lines?
Am I missing anything?
Old 02-04-2015, 11:10 AM   #8
LTRS777
LTRS777's Avatar
That sounds right to me, but im not sure. Havent dove into the fuel systems on these cars yet. It would be smart for a performance shop to make an e85 kit... Hell thousands have been spent to gain 15-30hp from intake pr head work, why not pay the same for guaranteed gains. *hint**hint* if bo believes 40whp is capable then itd be worth the investment
Old 02-04-2015, 12:03 PM   #9
Russell James
Russell James's Avatar
VP makes a version they call M85, more performance designed and consistent octane.
I wouldn't trust pump E85 on a boosted motor with the timing cranked way up unless testing the fuel and knowing what the quality is. That pump E85 stuff varies widely.
Old 02-04-2015, 12:06 PM   #10
Russell James
I wouldn't mess with it myself. I'd stick with 93 and the occasional race gas. Stick some racing unleaded in it and create a dyno tune for that fuel. Then whenever needing that 20 - 40 more hp.... stick some race gas and that race gas tune in it. Rest of the time you'll be cruising on 93.
Old 02-04-2015, 01:25 PM   #11
Bo White
Bo White's Avatar
The flex fuel file in the E38 computer monitors the content of the fuel once it's activated in the tune and will adjust according to the quantity of ethanol in the fuel.
Totalled:
Old 02-04-2015, 01:32 PM   #12
pdiddy
Drives: 2011 2SS
Bo are you saying the computer in the 2010+ cars has an option to be activated to pull timing based on the fuel? Is there something that needs to go along side with this like a flex fuel sensor or is it all in places just needs to be activated???
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 02-04-2015, 01:35 PM   #13
Bo White
Bo White's Avatar
Correct. It's just one wire that you pin into the ecu connector from the flex fuel sensor and go into the tune and cut that feature on.
Totalled:
Old 02-04-2015, 02:00 PM   #14
Unreal
Drives: 2006 Z06
You can use the flex fuel maps for either flex fuel, or you could even wire in a dial and have adjust a timing on a dial, something like 0-5 degrees. Many ways to use the flex fuel options.
Nick
Corvette Z06 -1200ish rwhp
