![]() Drives: 2010 2SS/RS Join Date: Jan 2015
"Early production"
I have been spending a lot of time on this site since I bought my 2010 2SS a couple of months ago. IOM, 478 rwhp, only 6200 miles. I've learned a lot but one issue still bugs me. My car was ordered in 2008, built May 2009, has chicklets, no back up sensors so I would assume it is an early production car but VIN says it is number 107,388. That doesn't seem like a low number to me. Am I missing something here? I know it doesn't effect anything but I am curious.
Thanks |
KaBoom1701
No idea...
But I'm sure some VIN experts will chime in shortly.
Mods:
Trust No One!
Drives: 2010 SIM 2LT/RS Join Date: Oct 2014
Mine is 105367. 04/09
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
lol who cares what the production number is. You've got one gorgeous color combo. if i didnt have the green and cyber gray, then red and white would be my next choice.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
There are specific issues associated with the earliest builds. However, I don't think there were 100,000 units produced for the 2010 models. I have a 2010 SS I purchased in 12/09 and it is 72,386. According the post below the sequence starts with 100001.
http://www.camaro5.com/forums/showpost.php?p=233103
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#6 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
When these cars were made they did not make them in order. Mine is #16429 and it's still a low/early production or an R6P RPO which designates that it's one of the first 10,000 Camaros pre ordered in the fall of 2008.
Yours may or may not be an R6P. To find out, pop your trunk, and pull back the carpet liner and you should find a square silver decal listing all of your option codes. If R6P is anywhere on that you have an early production 5th GEN. It really doesn't mean much other than it was one of the first 10,000 ordered.
#7 |
Look in trunk on left side under mat look for r6p on sticker
#8 |
Thread Ender
Drives: 2010 Camaro 2SS/RS L99 Join Date: May 2011
Mine is as yours, op, chicklets, no backup sensors. Build number 125xxx, built on July 09'. Every time I read the build sheet I learn something new. It came with sterling silver rims but the rs package turns them into midnight silver. Build sheet references both colors, so I was confused as of a few days ago. News to me!
#9 |
CamaroFans.com
That's exactly right... mine was 8675 and was delivered in May and built in April
#10 |
what do you guys mean by 'chicklets'
#11 | ||
CamaroFans.com
First off, welcome to the forum kwhman
Your car probably also has an R6P "pre-order" code on it. Quote:
#12 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I believe only the ZL1s and maybe Z/28s used sequential Vin numbers.
Via lightning from a large Hammer.
#13 |
#14 |
Drives: 2012 Camaro 2SS/RS Victory Red Join Date: Jun 2014
