Old 02-04-2015, 09:34 AM   #1
Gonzo.ss
Gonzo.ss's Avatar
Drives: 2013 Camaro SS
Kooks 1 7/8" installed, now have more questions
I finally had my headers installed catless.
Along with my other mods, it is freakin loud. I've had them on for 2 days and out of courtesy to my neighbors ( I go to the gym at 5am) I need to quiet it down a little bit.
I want to add the video but am having trouble uploading it (any suggestions)
Would adding cats back to the mix lower the sound a little bit ?
Also my butt dyno does not feel a drastic difference in power. I am having it tuned tomorrow, will that make the power more noticeable.
Mods so far:
Roto Fab intake.
Vmaxx ported throttle body.
Solo Axle back
Kooks 1 7/8" LTH Catless
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Gloss black stripes, gills,bowties and bezels
Gonzo.ss is offline   Reply With Quote
Old 02-04-2015, 09:48 AM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
L99 or LS3?
Going with cats would have helped a bit for sure. I would suggest installing a Magnaflow Resonated X-pipe to start. They are cheap($100), and significantly reduce the volume.
I installed one for the same reason after my cam install, but sadly my particular combination produced a resonance frequency that would rattle the fillings out of your teeth, so it was promptly removed the next day. Other than that, I was VERY happy with the results and am sad it didn't work out for me.
I would not let this scare you. I am a unique case, as a guy I know has the EXACT same setup as me and he didn't get that resonance issue I did.
After that, if still too loud, then there is not a ton you can do(try adding cats). I have even researched alternative cat backs and none will really be much quieter than my NPP with the flaps closed, and with the insane price for a cat-backs, it just is not worth the money.
Good luck man!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 02-04-2015, 10:47 AM   #3
Gonzo.ss
Gonzo.ss's Avatar
Sorry L99
Mods so far:
Roto Fab intake.
Solo Axle back
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Old 02-04-2015, 10:54 AM   #4
Gonzo.ss
Gonzo.ss's Avatar
I'm going to order x pipe today
Mods so far:
Roto Fab intake.
Solo Axle back
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Old 02-04-2015, 10:54 AM   #5
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
I 2nd the x pipe. I had the same issue as you. Leave for work early in the morning.
Before: http://youtu.be/Mpq0NjAQSK4
After: http://youtu.be/bLo3hk5ns5g
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 02-04-2015, 10:57 AM   #6
I4toV8
Dazed &
I4toV8's Avatar
Drives: matte blue 2014 z28(186) 2015 R1
every time i see these threads, it makes me love my neighbors more. OP tell your neighbors to move, your car is more important
I4toV8 is offline   Reply With Quote
Old 02-04-2015, 10:59 AM   #7
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
I see you have an axle back. Do you still have the stock L99 resonator on now?
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 02-04-2015, 11:23 AM   #8
Gonzo.ss
Gonzo.ss's Avatar
Yes , stock resonator in place
Mods so far:
Roto Fab intake.
Solo Axle back
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Old 02-04-2015, 11:30 AM   #9
Gonzo.ss
Gonzo.ss's Avatar
Did not think of using youtube
Before http://youtu.be/ljGABBz2Z80
After http://youtu.be/yvhE9o72Au0
What do you guys think ?
Mods so far:
Roto Fab intake.
Solo Axle back
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Old 02-04-2015, 11:35 AM   #10
GMTool
MY SS is SOLD
GMTool's Avatar
Well I can't imagine a magnaflow resonated x pipe is going to do much good on quieting it down on account that you still have the stock resonator. If it were me in your place I think I would get high flow cats, and put the stock mufflers back on. And get a tune as soon as you can. An L99 with headers and no tune has got to be very annoying with AFM. With a good tune you will definitely feel the increase in power especially the way the tranny will shift.
Old 02-04-2015, 11:37 AM   #11
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
It sounds awesome! Have your neighbors complained? Honestly...I'd leave it. Trust me you will get used to it and will think it's quiet. Starts your car up and don't jump on it till you get out of your neighbors vicinity.
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 02-04-2015, 11:57 AM   #12
GMTool
MY SS is SOLD
GMTool's Avatar
Yes it does sound good. What I said above about putting stock mufflers back on after you already changed the diffuser is not a good idea. I was thinking of what it would take to quiet it down.
Old 02-04-2015, 12:52 PM   #13
Gonzo.ss
Gonzo.ss's Avatar
Thanks everyone, I'm going to leave it alone for now, I have a range afm so no afm kicking in. I am getting it tuned tomorrow in the am.
I guess I was expecting a huge power difference but am guessing once it's all tuned properly I will feel it much more.
Mods so far:
Roto Fab intake.
Solo Axle back
1LE diffuser
SS Clones quad tips
Apex CAI scoop
Old 02-04-2015, 01:23 PM   #14
Pluto
Pluto's Avatar
Drives: 2013 Camaro 2SS/RS
Call me inconsiderate but I do not care what my neighbors think...I would leave it and let them get over it...I also do not purposely romp on my car in the neighborhood...not saying that you do..if I was driving normal in and out of the neighborhood I wouldn't pay any mind to anyone else
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list:
Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket.
Pluto is offline   Reply With Quote
