Old 02-06-2015, 04:36 PM   #1
Chrome4Me
Drives: 2010 2LT RS IBM
What is the average life of OEM Battery?
My 2010 2LT RS still has the original battery. The car is under a cover at the moment with about 6 inches of snow atop the cover, It's been below freezing over the last few weeks.
Should I expect to replace the battery once the weather changes?
Thanks
Tom
Chrome4Me is offline   Reply With Quote
Old 02-06-2015, 04:43 PM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
5 years is about the average life of a battery. It may or may not need replacement when the weather breaks.
TheHorse13 is offline   Reply With Quote
Old 02-06-2015, 05:04 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Since you are not hooked up to a battery tender, your 5 year old battery will be suspect in the Spring.
Under the best of circumstances, 7 years is about the limit. But in your case, it's probably time for a new battery.
Rock-It Man is offline   Reply With Quote
Old 02-06-2015, 05:44 PM   #4
CFD
Drives: 2SS/RS L99 BLACK
I'm still running my oem battery, it's a 2010, more importantly, I've got 99,898 miles and am in an out of my car maybe 20-30 times a day, that's a lot of starting which is the biggest drain on the battery, when it's time to be replaced, most likely going with another oem one.
CFD is offline   Reply With Quote
Old 02-11-2015, 08:19 PM   #5
DarKnightZ
DarKnightZ's Avatar
Drives: 2012 SS Black Camaro
My brother has a camaro (as well as my mom and dad lol) and he's had his for about 5 years and the battery is still pretty good, so yea it does last a pretty long time.
So far...
Borla Attak Exhaust
Volant Cold Air Intake
DarKnightZ is offline   Reply With Quote
Old 02-11-2015, 08:22 PM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
When I lived in Florida my OEM's lasted about 3 years max, the heat really played a toll on them. Seems though up north the weather is kinder to them.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-11-2015, 08:24 PM   #7
MLAZ1990
Drives: 2012 black camaro 2LS
Good thread, I've been wondering the same thing!
MLAZ1990 is offline   Reply With Quote
Old 02-11-2015, 09:14 PM   #8
Chrome4Me
I'll find out in a week or two once the snow on the cover melts. Haven't even had the doors open since December.
The car turns 5 this April and it's been very cold these last couple of weeks (in the teens a lot).
Keeping my fingers crossed.
Tom
Old 02-11-2015, 09:27 PM   #9
garyw
Drives: 2014 Camaro 2SS RS
depends on where you live, look at the responses of the people close to you. here in houston 3 years is average.
garyw is offline   Reply With Quote
Old 02-11-2015, 09:41 PM   #10
MLAZ1990
If I wanted to change my battery, what is the best one to purchase? Aftermarket or OEM?
Old 02-11-2015, 10:22 PM   #11
1KillerSS
1KillerSS's Avatar
OEM is good, I personally like Interstate Batteries.
Build thread
Old 02-12-2015, 04:00 PM   #12
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
My car will be 6 years old come May, still on the original battery. Sitting is probably the worst for them. Starting and keeping them charged will keep them in better shape. If you leave it sitting for long periods then a trickle charger is the best bet to keep it strong.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 02-12-2015, 04:40 PM   #13
Rock-It Man
The Camaro battery is in the trunk, so it doesn't get stressed by engine heat. The only OEM battery I had that failed before 7 years was in a cramped minivan engine compartment. It died after less than five years.
Old 02-12-2015, 05:33 PM   #14
CFD
Don't it figure. A week ago I posted how my oem battery was still going strong, well now a bit over 100,000 miles and after pulling in for gas it wouldn't start. Had to jump it, took it back to the shop and checked the charging system and all is good. It's been starting fine since then so it could be a fluke but I'm putting my money on it being a sign. lol.
