Old 02-06-2015, 05:45 PM   #1
Hardymon
Hardymon's Avatar
Drives: 2010 2SS LS3 Yellow
V8 Manual transmission fluid change
I've seen a number of people asking about this, and after a lot of searching, it was hard to come up with anything concrete, so now that I've done this, I figured I'd share it. This is really easy, and if you can change your own oil, you can certainly do this.
What you need: 3/8" square drive ratchet or breaker bar, oil catch pan and some sort of pump. The manual states that the capacity is 4.2 quarts if I remember correctly, so you should be good getting 5 quarts if you want to use a little to flush it with, but you could probably get away with just getting 4 since there is a little bit that will sit in the bottom of the tranny.
I actually bought 6, 5 quarts of RP Syncromax and a cheap quart of mobil 1 Dex III fluid to rinse the tranny with, (I can't call it a proper flush). In the end, I had an extra quart of RP unopened.
First thing to do is use your 3/8" drive to open the fill plug. Assuming you're running everything stock, just be careful of the sensor that's right there (see first picture). As you should be able to see, the plug is about 1/2 way up the tranny on the driver's side and it is labeled "FILL".
After the fill plug is out, set that somewhere safe.
Next position your catch pan under the drain plug which is located at the back of the tranny on the bottom on the passenger side, (second picture, the plug with the 3/8" square, not the bolt). (Sorry if that's super obvious, but what's obvious to most of us isn't always obvious to everyone).
*note* When positioning the pan, make sure that the edge of it is just under the drain plug, since, when you remove the plug, the fluid will gush out and may overshoot the pan if you don't have it positioned correctly.
Now you can remove the drain plug (also just a 3/8" drive), being aware that the fluid will drain out surprisingly fast.
Now there are two ways you can go here; you can reinstall the drain plug or do what I did and pump a bottle of cheap tranny fluid through to provide some rinsing/flushing action. If you don't feel this is necessary, then just reinstall the drain plug and begin pumping tranny fluid back into the fill plug.
If you're working at a shop, they may have a fancy machine to automatically pump it up in there, the hobby shop I was working out of just had a basic hand pump, (one more reason I opted to run a quart of the cheap stuff through, since I didn't know who had used it last or for what exactly). Also, it's good practice to wipe everything off for the reason I just mentioned; you don't want to introduce someone elses crud into your car.
Pump the first 3 quarts in as quickly as you're motivated to do, but on the fourth, start to slow down a little as this will likely be all the tranny will hold. Since there's no dipstick, once you start to see fluid leak out of the fill hole, poke your finger in there to verify that the tranny is in fact full, (fluid should be about level with the bottom of the fill hole), and that the fluid isn't just running down the pump's pipe.
Reinstall the fill plug. I don't have actual torque specs here, maybe someone can chime in with those, but you shouldn't need to gorilla grip either plug in there as there is thread sealant on them. I went until they felt snug and then gave an extra 1/4 turn.
All that's left is to turn the car on, make sure theres no leaks and enjoy!
Life's a garden, dig it!
Mods to date: Volant cai, New Era Ported TB, Torque Solutions short shifter, FE4 suspension with BMR Sway bars, SP 17/8" headers with hi-flo cats, Solo Performance cat back.
Hardymon is offline   Reply With Quote
Old 03-15-2015, 09:32 AM   #2
Tennis_pro
Drives: 2012 ZL1
Good post man. I will be doing this very soon. Would it be safer to remove the electric connection before doing this to make sure you don't get trans oil on it? Also, did you have your car exactly level for this?
Tennis_pro is offline   Reply With Quote
Old 03-15-2015, 03:38 PM   #3
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
Nice write up Hardymon. For those that do not have access to a Hobby Shop or a hand pump. You can make your own with a simple 3/8" marine priming bulb, some 3/8" fuel vapor hose and a Napa 3033 filter. Just make sure the filter is installed after the pump to collect anything the pump might discard.
cajun1le is offline   Reply With Quote
Old 04-18-2015, 12:26 AM   #4
Hardymon
Hardymon's Avatar
Yes, the car was level on a lift. I didn't disconnect anything either. Where the plugs are, there shouldn't be any issues with oil getting on the connections.
Old 06-05-2015, 12:38 AM   #5
thebigbankhank
Drives: 03Avalanche,2012cbr1000rr,2010iomSS
How many miles are recommended for a fluid change
thebigbankhank is offline   Reply With Quote
Old 12-18-2015, 06:52 PM   #6
LadyT_SS
Christina
Drives: Red Jewel Tint 1SS
Torque specs on the fill and drain plugs?
LadyT_SS is offline   Reply With Quote
Old 12-19-2015, 05:31 PM   #7
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
20 foot lbs or 27 Nm
GVA 45TH 2SS is offline   Reply With Quote
Old 12-27-2015, 03:46 AM   #8
wreeino
Drives: camaro
wreeino is offline   Reply With Quote
Old 12-27-2015, 12:50 PM   #9
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Manual tranny's don't have filters as far as I know .
Nice write up OP.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 09-25-2016, 09:07 PM   #10
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
Thank for the write-up and pics. Just another reason I have yet to purchase a repair manual. I will be doing this within the month.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 07-31-2021, 11:39 AM   #11
InfernoSSDC
InfernoSS
Drives: 13 Camaro SS
Great write up, as im about to flush mine.
InfernoSSDC is offline   Reply With Quote
change, manual, manual transmission fluid, v8 manual transmission
