Old 08-27-2009, 03:45 PM   #1
jimfin
Drives: 2SS, Yellow/RS, Volvo XC90
Engine Noise in the V8 Automatic at 1400 rpms
There is something that I noticed and are wondering if anyone else with the V8 Automatic hears the same thing. When I'm driving in the streets and i hit the gas and get the car up to 2000 rpm's it sounds normal. If I have to slow down and the rpm's drop down to 1200-1400 rpm's there is a sound that comes from the engine almost as though its down shifting, but its very pronounced. I don't lose any power, but it doesn't sound right to me. I had my exhaust upgraded (GM Performance) and an air box installed and now the noise sounds more "raspy" for lack of a better word. My machanic noticed this, but had no explanation. He really doesn't know enough about the car to tell me if this is normal. Is it possible the L99 engine steps down cyclinders (goes from 8 to 6) at lower speeds and thats what I hear. Any help will be appreciated. Thanks
jimfin is offline   Reply With Quote
Old 08-27-2009, 04:07 PM   #2
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
the L99 only goes V8 to V4 and back never does it go to 6, just to clear that up for ya
does it only do it when off the gas or does it do it during cruising as well
Gentry78 is offline   Reply With Quote
Old 08-27-2009, 04:17 PM   #3
Sloppy Joe
Sloppy Joe's Avatar
Drives: 2SS RJT
It's the AFM kicking in and out that your hearing. A bit annoying, but its completely Normal for the L99. Gentry is right its 8 to 4 , there is no 6 cylinder mode.
2SS, RJT, Gray interior, 6 Speed Trans /w TAPshift, silver stripes and polished wheels
Sloppy Joe is offline   Reply With Quote
Old 08-27-2009, 11:26 PM   #4
BlemsBumble
BlemsBumble's Avatar
Drives: '13 ZL1 #662; '10 SS; '99 SS
Get used to it.
BlemsBumble is offline   Reply With Quote
Old 08-27-2009, 11:30 PM   #5
JSOC_MQ1
Drives: 2010 IBM 2SS
That noise is why the stock exhaust has the "huge" resonators on it. You will hear the same thing if you are crusing down the highway and start to go down a hill.
JSOC_MQ1 is offline   Reply With Quote
Old 08-28-2009, 10:31 AM   #6
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
It sounds like the guys here may have pinpointed the problem for you.
But last week I had my AC compressor replaced... it had a bad bearing.... from the day I picked it up it was making a whining noise at certain RPMs close to what you mentioned.
Just in case my explanation sounded familiar. I have an LS3 though.
Old 08-28-2009, 10:44 AM   #7
DDustiNN
DDustiNN's Avatar
Drives: Cars
What did it sound like? I noticed a noise from behind my dash, toward the center, when I'd rev somewhere betweek 2-3k RPMs. It's hard to explain the noise, but it almost sound like a "tinny" noise or something... Gah, I really don't know how else to describe it. I'll see if it's still there when I get my car back. If it is, I guess I'll have the dealer check it out.
DDustiNN is offline   Reply With Quote
Old 08-28-2009, 10:50 AM   #8
BrianGriffin78
BrianGriffin78's Avatar
Drives: 2009 GMC Yukon
That is the cylinders shutting down from 8 to 4, to give you the better gas mileage. If you drive in M mode, aka Sports mode you should not hear that.
BrianGriffin78 is offline   Reply With Quote
Old 08-28-2009, 11:17 AM   #9
DDustiNN
DDustiNN's Avatar
Drives: Cars
Does Sport Mode eliminate AFM? I haven't heard of that before... That would be interesting...
Old 08-28-2009, 07:41 PM   #10
Kyle.Gilmour
If the AC is off, it wont make the noise. If you are wondering if it is the same thing, shut the AC off and see if it stops.
Old 08-28-2009, 11:52 PM   #11
BlemsBumble
Not a chance.
Old 08-29-2009, 12:28 AM   #12
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
I thought I read that the v8-v4 shift happens near the 1800 rpm spot.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 08-29-2009, 12:39 AM   #13
29er
29er's Avatar
Drives: 14 1LE Garage King
turn up the radio higher.. just a joke!.. have it road tested at your dealer ...
29er is offline   Reply With Quote
Old 08-29-2009, 01:30 AM   #14
jimfin
Off the gas
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
LS3 and other engines/transmissions Mungo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 158 03-21-2008 03:30 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
