Old 02-07-2015, 01:07 PM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Alignment/ pulling
So my alignment seemed to be off a bit. When I had the wheel straight it pulled to the right quite a bit. Took it to the dealer to get the alignment done and once they were finished, it was pulling literally twice as bad and I regret even taking it lol.
Either they don't know what they are doing or there is a different issue going on..
I am running a staggered set up with new perelli PZero's.
I plan on switching wheels (driver side to passenger and passenger to driver) to see if it still pulls in the same direction.
Any other suggestions?
Thanks
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 02-07-2015, 01:48 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Check your air pressure, then take it back to the dealer for him to align the car again free. He messed up somewhere and should redo the alignment free.
Dimitrim is offline   Reply With Quote
Old 02-07-2015, 03:47 PM   #3
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
I've had mine aligned twice in the year I've owned it. Both times same place, they do good work. Make sure you have a four wheel alignment done and if they have a road force balancer, have them balance the wheels with it also. Maybe the place you took it to only aligned the front wheels and not the back as well.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 02-07-2015, 07:42 PM   #4
bionick
bionick's Avatar
They did front and back im just very frustrated because it's worse after they made adjustments.. Lol
Old 02-08-2015, 07:46 AM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Make sure you are not just experiencing pull to the right on a crowned road.
Rock-It Man is offline   Reply With Quote
alignment, pulling
