Old 02-10-2015, 09:39 PM   #1
14ZL1M6
14ZL1M6's Avatar
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6
MGW Shifter
Who has one? Whats your opinion? Pros or cons? I have a Hurst now and have had my eye on switching to the MGW.
Thanks
14ZL1M6 is offline   Reply With Quote
Old 02-15-2015, 12:54 PM   #2
14ZL1M6
14ZL1M6's Avatar
Bump....Anyone?
Old 02-15-2015, 01:00 PM   #3
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Ran one on my SC SS. When I switch my shifter in my Z it will be to a MGW.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 02-15-2015, 01:16 PM   #4
14ZL1M6
14ZL1M6's Avatar
Was it a smooth shift? I like my Hurst, it has a tight pattern but the movement is real stiff. I like how the MGW is the whole base and linkage. Looks like a real quality shifter.
Old 02-17-2015, 04:13 AM   #5
BattleScarredSoldier
BattleScarredSoldier's Avatar
Drives: 14 Camaro ZL1, 87 Grand National
Ordered mine a couple weeks ago, and they are on back order if that says anything to their popularity. Called them yesterday and was told it would ship out today. Will get mine installed in a couple weeks, if you havent made a decision yet I will let you know.
Vengeance Racing + Cat and Muffler Delete > Viagra
BattleScarredSoldier is offline   Reply With Quote
Old 02-17-2015, 05:58 AM   #6
macSS
macSS's Avatar
Drives: 2012 SS Camaro LS3
MGW all the way...you will never miss a shift and its built like a tank...Its a work of art and customer service is outstanding....spend the money and do it right the first time.
2012 Ashen Grey LS3_ARH 1 7/8 Long tubes_Pypes Exhaust Axle Back_C.A.I._
Bo White Ported Throttle Body_Custom Black Anodized Fuel Rails_3:91 Rear
ARP Stainless Bolts_MSD Wires_Elite Engineering Catch Can_MGW Flat Stick_Stewart Warner Pro Gauges_BMR Rear Suspension_ZL1 Rear Swaybar
427 HP To The Wheels_Tuned and Dyno'd by ECS
macSS is offline   Reply With Quote
Old 02-17-2015, 06:59 PM   #7
14ZL1M6
14ZL1M6's Avatar
Thanks, I would appreciate your feedback.
Old 02-17-2015, 07:02 PM   #8
DrkPhx
DrkPhx's Avatar
I would like to hear some feedback compared to the ZL1 shifter which I do like. I read on the Vette forum that some couldn't speed shift as quick as the stock shifter which doesn't make sense.
Old 02-18-2015, 09:07 AM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
I installed a MGW Shifter after missing a no-lift shift on the stock shifter at the track on a stage one package that put down 570 rwhp/570 rwtq. For me, the stock shifter did not engage quick enough as the power level increased.
I rarely have missed a shift on the street or track with the MGW shifter at the current power levels (670 rwhp/630 rwtq), but I do not No-Lift shift anymore. To0 risky on the street on with Factory rubber and too costly at the track at this level.
Pros; Shorter throw and solid direct engagement. The shifter is a work of art. I wish the billet housing and platform could be exposed somehow.
Only Con. The spring is tighter and you will need more effort on gear engagement. You will get you used to it and probably like it more after a week or so. I know I did.
Hope that helps
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 02-18-2015, 10:24 AM   #10
DrkPhx
DrkPhx's Avatar
^^^^ Awesome. That's been my experience as well and one reason I wanted to switch. Thanks for the info.
Old 02-18-2015, 12:12 PM   #11
14ZL1M6
14ZL1M6's Avatar
Hope that helps
That was the feedback I was looking for, thank you.
Old 02-18-2015, 12:43 PM   #12
forklord
forklord's Avatar
Drives: 2010 2SS
i have the mgw. i had the hurst. if feels very solid, well built and smooth but you kinda do need a bit more effort in the shifts. its alright. dunno if its worth the time and money tho.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
