Old 02-11-2015, 07:47 PM   #1
ssfox
ssfox's Avatar
Drives: 2011 2SS/RS Vert
Frameless Mirror Install
Just installed a 2013 frameless mirror in my 2011 from Gen5diy.
Question I have is should any of the icons or anything on the mirror glow to tell me the mirror is working?
Note - I do not have a active onstar subscription.
Not sure why photo is upside down.
2011 2SS/RS VERT
Moroso Catch Can,K&N CAI,Apex Air Scoop & Washer Relocate,ZL1 Grille,GTO Clutch Rez, Frameless 2013 mirror.
Tuned by MGS Performance
ssfox is offline   Reply With Quote
Old 02-11-2015, 09:14 PM   #2
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Are you posting from an Ipad? that is a known issue on here with the pictures posting upside down.
If you're not getting any lights, something was missed with your electrical connections.
Old 02-11-2015, 09:41 PM   #3
ssfox
ssfox's Avatar
Problem solved.
You have to put the fuse you remove back into the add a fuse (2 fuses in total) before everything will work.
And yes, posting from a iPad.
2011 2SS/RS VERT
Old 02-11-2015, 09:42 PM   #4
ssfox
ssfox's Avatar
Thanks for your response.
2011 2SS/RS VERT
Old 02-11-2015, 11:43 PM   #5
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
Originally Posted by ssfox View Post
Problem solved.
Yep, I did the same thing.
Aequitas & Veritas is offline   Reply With Quote
Old 03-21-2015, 03:59 PM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I tried this.
Wiring looks good, everything connected, still nothing.
No lights, no response from OnStar.
Any ideas?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-21-2015, 04:44 PM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
I did the same upgrade last year and after a 1 week I' e unplugged the connectors for the mirror... could not stand the illusion of police lights flashing at me at night.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 03-22-2015, 04:20 AM   #8
Spartan01
Spartan01's Avatar
So, again, any ideas?
No lights, no OnStar, nothing.
I checked to make sure both fuses were in the add a fuze,
Still nothing.
Any help is appreciated.
Old 03-22-2015, 04:45 PM   #9
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Still nothing.
Same here,got everything hooked-up ok,but no power to the mirror.
I'm going to PM Ofer and see if he has any troubleshooting ideas/tips.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 03-23-2015, 07:37 PM   #10
Mikamaro
MikeNoMaro
Mikamaro's Avatar
I would ask gen5diy
Old 03-23-2015, 08:59 PM   #11
MS3DALE
MS3DALE's Avatar
Originally Posted by Mikamaro View Post
I would ask gen5diy
Yep,I've been in contact with Ofer all day today,I'm trying different things to see if I can find the fix.
Old 03-24-2015, 11:39 AM   #12
Spartan01
Spartan01's Avatar
Me too,
he said to check the single green wire and its male connection.
I did, it had some play in the connector itself even once it was snapped together.
But I still could not get it to work
Old 03-24-2015, 11:48 AM   #13
MS3DALE
MS3DALE's Avatar
Working at a Chevy dealer with lotsa' Camaro's on the lot....I tried my frameless mirror in a new 2015 Camaro we have here,and it worked fine,so I know my mirror is good.
I also plugged my OE non-frameless mirror into my car using the harness and it worked as well (although I don't if that really means anything or not)
Now what I'm going to do this afternoon is take the original frameless mirror out of that new 2015 I plugged mine into and try it in my car,I figured it can't hurt to try a new different mirror!
Old 03-24-2015, 01:36 PM   #14
Spartan01
Spartan01's Avatar
Good idea!
anyone in the Falls Church area that will let me test my new frameless mirror out? I will buy you a beer.
