Old 02-14-2015, 08:22 PM   #1
L99CAMA2011
L99CAMA2011's Avatar
KONY YELLOWS are here
Just checked out TireRack and saw these http://www.tirerack.com/suspension/s...utoModClar=1SS.
Old 02-14-2015, 09:20 PM   #2
JusticePete
Drives: Camaro Justice
With the 1LE and DSSV struts available from GM, why are these of interest?
Old 02-15-2015, 08:57 AM   #3
L99CAMA2011
I had the 1LE struts and they honestly don't feel of quality and the oil contents made the struts feel cheap, made that sound like the oil would easily foam up with heavy use. The Z28 pieces aren't available unless bought with the whole suspension kit so these fit in where some may not need coilovers but want better than 1LE performance. Gen 4 Camaro owners I met told me they liked Koni Yellows a lot on track plus they have levels of adjustments , 3 I think. If the z28 pieces are available as just shocks and struts let me know.
Old 02-15-2015, 01:57 PM   #4
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
I think the Koni may offer an option to those who do not want/afford coilovers, BUT ONLY if they offer an advantage over the OE 1LE struts. I had the single adjustable (rebound) yellow Konis on my 4TH gen '95 with Eibach then Strano springs and they worked great. There also was the double adjustable which added compression adjustability. Both sets were beyond just 3 levels of adjustability, could adjust to any point within the soft and stiff limits.
From what I have read the Z/28 springs are quite a bit stiffer so the Z/28 strut/springs may be too much for some. And if the Z/28 struts were available alone, would they even be feasable with a softer spring?
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 02-15-2015, 03:33 PM   #5
2ss-booya
2ss-booya's Avatar
Drives: 2015 SS Sedan M6
And how many different setups have you gone though now? Lol
2ss-booya is offline   Reply With Quote
Old 02-15-2015, 06:51 PM   #6
L99CAMA2011
Damn didn't someone steal your ZL-1.
Old 02-15-2015, 06:54 PM   #7
L99CAMA2011
Softer spring works the strut/shock more, not a good idea. I have the Z28 spring on the rear of my Bilstein Pss10 kit and it works great. Feels like I need to go back to the BMR rear sway bar which is a bit softer than the DSE rear bar.
Old 02-16-2015, 11:12 AM   #8
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
For the price of those Koni Yellows, you could spend 600 more bucks and have the entire 1LE setup, minus wheels/tires of course.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 02-16-2015, 04:36 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
It's about time! These have been long awaited.
Best regards,
Tyler
888-308-6007
Old 02-16-2015, 05:58 PM   #10
cdb95z28
cdb95z28's Avatar
Coilovers, $2100 for Ridetechs
Apex/Pfadt springs $200 + Konis $900=$1100
Many advantages to the Ridetechs vs lowering spings.
That $1000 saved can be used for camber plates.
Old 02-16-2015, 06:09 PM   #11
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
I'd like to see someone with a shock dyno back-to-back compare the following, new out of the box.
-OE SS struts
-OE 1LE struts
-OE Z/28 struts
-Koni Oranges
-Koni Yellows (on each adjustment)
that way if you want more damping, but don't want to go to coilovers, you really know what you're options are. You could run a good set of struts with a stiffer set of springs, and JusticePete's knuckles, and have a good, consistent setup that behaves with the OE geometry.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out!
Burt is offline   Reply With Quote
Old 02-16-2015, 07:01 PM   #12
Scotty D
Drives: 2014 1le 1SS CRMT
At $1100 for springs and shocks . Just go with BC coilovers @ that point ! Right ??
Scotty D is offline   Reply With Quote
Old 02-16-2015, 07:10 PM   #13
X25
X25's Avatar
Drives: '16 C7 Z51
I went to track with both 1LE shocks, and then Z/28 setup on my 1LE, and both performed admirably. I ended up doing 1:58.2 with 1LE shocks, and 1:57.2 with Z/28 shocks. I bet the gap would widen with R-compound tires, but I never felt under-dampened at the track with 1LE shocks. Keep in mind, they are monotube unlike standard SS suspension.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 02-16-2015, 07:17 PM   #14
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
Exactly what I was thinking too?? and Megan Racings are $900. with 32 levels of adjustments.
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
