02-16-2015, 11:32 PM | #1 |
bought a used supercharger
So I bought a used supercharger off a CTSv with a zl1 lid. It has about 50k miles on the unit. I'm buying the install kid from ADM.
Anything you all think of I should replace before putting it on my car?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
02-17-2015, 06:03 AM | #2 |
Drives: Anything I want Join Date: Oct 2008
02-17-2015, 06:05 AM | #3 |
And at least a ls9 cam.
02-17-2015, 08:15 AM | #4 |
My car already has long tubes no cats full exhaust cold air intake (pointless with the LSA now). I ordered the can kit plus from vengeance racing. The can I got was their VRPD2 cam 231/239 .617/.624 118+4
It comes with: 5/16" Hardened Pushrods, .660" Lift Dual Valve Spring Kit, C5R Timing Chain, Melling Hi Volume Oil Pump, Comp Cams Trunion Upgrade, GM Front Cover Seal, GM Front Cover Gasket, GM Waterpump Gasket Set, GM Crank Bolt, ARP Cam Bolts, LS7 Timing Gear, LS2 Dogbone Timing Damper Anything I should look at for the supercharger itself far as upgrades or maintance?
02-17-2015, 01:12 PM | #5 |
Drives: Black 2SS Join Date: Oct 2009
Might want to upgrade the fuel system.
02-17-2015, 05:29 PM | #6 |
My car came factoy with ZL1 pump. So I have two of those Lol bought one before I knew it came factory with one.
02-22-2015, 06:23 PM | #7 |
Want to sell that ZL1 Pump? xD
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
02-22-2015, 06:31 PM | #8 |
Do all new ss's come with the zl1 pump? I thought just the 1le did?
