Old 02-18-2015, 08:30 PM   #1
TrillChevyRyda
TrillChevyRyda's Avatar
Drives: 2011 2SS Camaro/79 Caprice LS
are the seat belts different for years and models?
i swapped seats with someone who had a 2011 RS camaro. I have a 2010 2SS and the seat belts do not click in. the seat belt buckle came from his car as they are attached to the seats. My buckle lock does not even come close to fitting. well anyways he sold his so i cant swap em out
Im looking for the correct seat belt buckles that match the 2011 RS..not sure if if they are different because of the year or model. any info?
http://www.camaro5.com/forums/image.php?u=51358&type=sigpic&dateline=1359702973
TrillChevyRyda is offline   Reply With Quote
Old 02-19-2015, 09:42 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Yes 2010 is a car onto its self, but you can remove the seat belt buckle out of the 2010 seats and mount them in your new seats.
Old 03-17-2015, 01:08 PM   #3
Char1ieone
Fear the Red Bow Tie
Char1ieone's Avatar
Drives: 2010 Black Camaro 2SS/RS LS3
Can you direct me to a thread that describes the process? I too have the same issue with my new 2011 seats swapped into my 2010 SS.
Char1ieone is offline   Reply With Quote
Old 03-17-2015, 01:21 PM   #4
2SSRS@Gen5diy
There is only one bolt on the side of the seat for the seat belt buckle, its a torx dont remember the size, and one 2 pin connecter under the seat, there the same connector so your good to go.
Old 03-17-2015, 10:29 PM   #5
Char1ieone
Char1ieone's Avatar
THANKS! Its was very easy, aside from having to remove both seats again and then realizing that it's only the driver side belt fastener that needs to be swapped. Oh well, hahaha.
