Old 02-19-2015, 09:24 PM   #1
DetCamaro15
Drives: Black 2015 Camaro
2014 2015 difuser ZL1 vs 1LE
Can anyone state the specific differencesZL1 and 1LE? Installing quad tipped MRT V1
Part #
ZL1: 22829478
1LE: 22829477
Any ideas? thanks
1LE:
DetCamaro15 is offline   Reply With Quote
Old 02-19-2015, 09:26 PM   #2
DetCamaro15
ZL1: 22829478
Old 02-19-2015, 09:42 PM   #3
AG1LE
AG1LE's Avatar
Drives: '14 1LE
SS/1LE top vs ZL1 bottom
AG1LE is offline   Reply With Quote
Old 02-19-2015, 10:08 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
just went through this the other day...
If you look closely at the ZL1 diffuser the is a shinny / glossy insert that surrounds the quad tips.
It's hard to see but they are there.
Mods:
Old 02-19-2015, 10:24 PM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
The insert around the quad tips is metal
The other major difference is along the sides (matches the ZL1 rockers), and the lower middle section is solid
Old 03-03-2015, 11:13 AM   #6
DetCamaro15
Thanks man really helped me out.
Old 06-18-2016, 12:16 PM   #7
Camaro2SS82
Drives: 2014 Camaro 2SS
Camaro ss lower cover
So both 1Le and ZL1 diffuser will fit a 2014 camaro ss?
Camaro2SS82 is offline   Reply With Quote
Old 06-19-2016, 05:53 PM   #8
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
Yes sir. All interchangeable, even for the Z28 one.
hzisfrom1994 is offline   Reply With Quote
Old 06-19-2016, 06:02 PM   #9
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Doesn't one of them have a heat shield for the exhaust ?
Dmpsix is offline   Reply With Quote
Old 06-19-2016, 11:12 PM   #10
hzisfrom1994
ZYJ
ZL1 has the heatshield, is optional and it doesn't come when you order the ZL1 diffuser. is like 240 for both left and right side...
Old 08-24-2016, 11:55 AM   #11
SSty1le
Drives: 2015 2ss
oh lol nvm then, do you know anywhere to get similar good ones? and one more question i was thinking about getting zl1 diffuser butit looks like the mud flaps stick out can that be taken off if you dont want it or is it all solid one piece with the diffuser. your inbox is full i couldnt send you messages
SSty1le is offline   Reply With Quote
Old 08-24-2016, 12:30 PM   #12
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
I'm pretty sure the mud guards are optional
Sent from my campfire using smoke signals
Superman09 is offline   Reply With Quote
Old 08-24-2016, 02:13 PM   #13
HogsFan75
HogsFan75's Avatar
Drives: 2015 2SS/RS/1LE
Curious about something. I was under my 1LE yesterday and the diffuser has attachment points for something and quick connects in the center. Is there an optional belly pan or something that connects to these?
HogsFan75 is offline   Reply With Quote
1le, diffuser, exhaust, fascia, zl1
